Project Mercury By Snakez Last update 14/02
Discussion in 'Project Logs' started by Snakez, 17 Nov 2006.
  1. Jipa
    5 Feb 2004
    ffs learn to use the EDIT-button. In dark the side panels look like they could just as well be gloss black :O You manage to make this look better every time I check it!
  2. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    If it looked like Caprica 6 i'd steal it.
  3. Snakez
    Snakez What's a Dremel?
    23 Dec 2005
    The second vga card did arrive :)
    Thnx [​IMG]
  4. Koradhil
    Koradhil What's a Dremel?
    9 Nov 2004
    Aren't you going to have a problem mounting the tubing at the VGA cards this way? The exit at the 2nd card points towards the 1st card...
  5. Snakez
    23 Dec 2005
    Don't have the fittings on there final position yet , will see when i have the tubing. And EK blocks have the option for fittings on both side of the cards.
  6. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    I was thinking the exact same thing, lol. Lucky they can be switched, eh?
    I still can't get over the shininess of this mod Snakez, it's just insane, lol.
  7. Snakez
    23 Dec 2005
    Today received the Tygon tubing.
    Let's try them out :)
    And some lights on.
    Now have to wait for pump and hoseclamps , dan install it all , and see if the tubing needs some more changes.
  8. Infenro
    Infenro What's a Dremel?
    7 Oct 2005
    again nice work, loving the whole layout of the kit inside, im still amazed by the amount of sponsors on this as well, good to know that there are so many.
  9. KlavKalashj
    KlavKalashj What's a Dremel?
    7 Sep 2006
    Hi! I think it looks really nice. But wouldn't the wc-loop look much cleaner if you flipped the rear singlerad upside down? Then you woulnd't have that issue with the hardly bent tube for the gfx-waterblock. Just a thought. Really good job, I like it!
  10. Snakez
    23 Dec 2005
    Changed the wcsetup after a tip from KlavKalashj at Bittech . Turned the back radiator 180 degrees. Tubing looks much better now. Thnx KlavKalashj :)
  11. Snakez
    23 Dec 2005
    Just a small update. Have bin working on the coverplate coverplate , made space for the atx , ide and sata cable's , and put some leds in it.
  12. stigmata
    stigmata What's a Dremel?
    26 Sep 2003
    Nice work man! :jawdrop:
    You're giving me some nice ideas... ;) :dremel:
    Just one question: I see a lot of people using these Tygon tubings... what's so special with them? I've sometimes used silicone tubing - for its softness - but it's not transparent like this.
  13. Snakez
    23 Dec 2005
    Tygon tubing is much better to work with , you can bend it very far without knicking it. Also it is much more expensive , but worth it.
  14. Mother-Goose
    22 Jul 2004
    looks good snakez, the tubing looks alot cleaner after the change of rad position too, I am loving the dominator cooler lol sad I know but its cool!!!
  15. Snakez
    23 Dec 2005
    I like it too , and saw that people are copying my idea allready , making a new cover on it :)
  16. Snakez
    23 Dec 2005
    Just received the power supply :p
    Thought would be an 850watt , But is the Real Power Pro 1000watt Modulair from Coolermaster . :)
    Thnx Coolermaster :)
  17. stigmata
    26 Sep 2003
    do they have modular psu's?
  18. Snakez
    23 Dec 2005
    Not for sale yet , is a prototype
  19. stigmata
    26 Sep 2003
    I'll ask them one :D
  20. Guest-23315
    Guest-23315 Guest
    I thought they didn't make those :D
    looks like the same design as the Silverstone striders
