Project Metaversa: LCD goodness (small update 17/07/05)
Discussion in 'Project Logs' started by Nexxo, 11 Apr 2003.
  1. KAMIKAZE-FREAK
    KAMIKAZE-FREAK What's a Dremel?
    30 May 2004
    a friend of mine also has that case
    he made it very neat and won the Casemod competition of Campzone 2004
    chemical overdose was second (and we all know chemical overdose)
  2. Risky
    Risky Modder
    10 Sep 2001
    Oh, if you're hacking at the newer intel chipsets there's a case for adding southbridge cooling as well:D
  3. slater
    slater Mummy Says Im Special
    18 Apr 2003
    Holy fook! :eeek: i wish i had one of those stashed in my bedroom, It must be worth £100s nowerdays :naughty:
    Seriously tho this is one of the best ive ever seen :thumb:
    slater..
  4. calking13
    calking13 What's a Dremel?
    15 Jul 2004
    Correct Me if I am wrong but is that 2 AGP slots in the mobo you are using?
  5. Nexxo
    23 Oct 2001
    I should be so lucky! :D Nope, the MSI K7D Master-L has only one AGP slot. No dual AGP slot mobos exist (well, none in which both can be used simultaneously, anyway). But if I'm wrong, please lat me know! :naughty:
  6. calking13
    15 Jul 2004
    then what are those two big slots for?
  7. Nexxo
    23 Oct 2001
    Those are 64-bit PCI slots ("regular" PCI slots being 32 bit). Only dual CPU server motherboards tend to have those. Because of their serious bandwidth, they're great for PCI RAID cards. Most "regular" PCI cards will also fit in them but will only operate at their usual 32 bit, of course.
  8. KAMIKAZE-FREAK
    30 May 2004
  9. Nexxo
    23 Oct 2001
    Thanks for the link! :thumb: In fact as soon as you had mentioned it, I hit Google and studied the article in great detail. :D
  10. KAMIKAZE-FREAK
    30 May 2004
    dont forget that that guy made his own software controlled ccfl & fancontroller
    and wrote the software for that controller
  11. Nexxo
    23 Oct 2001
    I know. That's the sort of geek-ness I can only aspire too... :(
  12. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    Got any links to the project log or detailed pics for that projekt ?
  13. KAMIKAZE-FREAK
    30 May 2004
  14. Turbokeu
    Turbokeu Minimodder
    30 Jul 2002
    Sorry, didn't remember that (getting older... :rolleyes: )
    In that case there will be a little "divider" problem.
    The SF800 puts out a frequency between 50 and 2000HZ (for a measured flow between 0.05 and 20.0 LPM).
    Most monitoring softwares (so does MBM) permit only dividers of 1,2,4,8,16 and so on for fan headers, but the signal of the SF800 should be divided by 100 to obtain a readout in LPM.
    A divider of 1 would give you a readout in cl (centiliter, 100cl=1liter).
    A readout of 547 would then correspond to 547cl/minute=5.47liter/minute.
    CD :)
  15. Xoddoza
    Xoddoza What's a Dremel?
    13 Jun 2004
    I've read through this log 3 times and each time i'm amazed at how bloody good it looks.
    Sigh. Excellent work.
  16. Nexxo
    23 Oct 2001
    Update: leak test no. 2 today --it is all OK now: we got liquid cooling! :thumb: Also installed the inverters for the CCFLs (which come in nice polished aluminium casings), and finished some more wiring. The PC is very close to firing up for the first time now. Pics tomorrow, as I can't be asked to upload them right now...
    Then to focus on the case lighting and outside "prettyfication"... :naughty:
  17. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    aluminum inverters huh? they sound like if there was a fault to them, they wouldn't pull the recent exploding/melting inverter trick.
  18. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Sounds bling, need to find some decent inverters for my next project, the ones the CCFL's come with pop after a few months use :rolleyes: Glad to hear an update is on the way :D
  19. Nexxo
    23 Oct 2001
    Update pics as promised:
    The polished inverters (even though where they are mounted won't be very visible)...
    And some pimp shots of the system. All the cables that are going to be in there, have been put in now. The cooling system has been filled and test-run (all OK).
    I am now turning my attention to the finishing touches of the actual electronics, and trying some ideas for the inside case lighting.
    Hmmm. Needs some white laserleds to highlight details. Or blue? Or red? Purple? Decisions, decisions...
    When that has been done, I will start doing some cosmetic stuff to the outside of the case --side panels, mostly. EL backlight, window, details...
    OK. 'nuff pimping. Time to get back to work. :dremel:
  20. Leeum
    16 Feb 2004
    Excellent work, is the hardware all working? :D
