Scratch Build – In Progress [Project] Midnight Sparkle
Discussion in 'Project Logs' started by x06jsp, 27 Oct 2008.
  1. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    Hey there guys,
    Im back again with another mod, This is Midnight sparkle that i am doing for my girlfriends new computer.
    as usual its a scratch build.
    Here is the initial design which changes a bit as you will see very soon(im not doing another version you can see in the pics)
    I started off this long day of modding by clearing stuff a bit so that i have room to mod again
    And on with the modding :D
    (sorry for the blurry pic...)
    I started by cutting apart my old case to give me a mobo tray and a template for the psu.
    mobo tray cut down
    and even more
    psu template
    I then cut the 2 bits of alu that i need for the main body of the mod
    and bent the longer bit to shape
    here it is with the side panel sitting on it
    and mounted
    front and back marked out
    and cut
    back marked for cutting
    cut
    mobo tray mounted
    Window cut
    and filed
    and mounted back on the case
    Acrylic for the window marked ready for cutting
    and placed on the outside of the case
    i then marked the alu angle ready for cutting into the joints
    and cut
    I then started work on the case feet
    and glued
    i didnt get to file, sand and polish them today but i will get that done tomorrow and then i need to order more bolts and get some more rivets tomorrow so that i can get this done. this will be one very quick mod butttt i did work on this from about 10:00-18:30 with a 1 hour break in the middle hence why i got a lot done :D
    and just to give you guys some perspective of size this is smaller than the mobo section on modularis :D
    Check in tomorrow
    Josh
  2. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    I was just going to mention the amount that it reminds me of Modularis' shape :p
    Looks good so far:)
  3. x06jsp
    2 Apr 2007
    Yer :D thanks
    Josh
  4. Nolimited
    Nolimited What's a Dremel?
    12 May 2008
    you love the Octagon ;) nice start :thumb:
    Will it paint in black
  5. x06jsp
    2 Apr 2007
    Thanks :D yer this one is getting painted black with blue metallic flakes in the clear :D
    Josh
  6. Attila
    Attila still thinking....
    22 Feb 2008
    Looking good, and very nice bending.
  7. x06jsp
    2 Apr 2007
    Thanks i try my best :thumb:
    Josh
  8. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Josh is keepin busy :D looks like another kick-ass project. Shes gonna luv it!
  9. x06jsp
    2 Apr 2007
    Thanks Bill :D
    and yer im trying to keep busy as i wont have as much time soon .... (job)
    Josh
  10. x06jsp
    2 Apr 2007
    Anyways today i didnt get much time as i was with my girlfriend but i did get the feet polished :D
    Josh
  11. skullen
    skullen Minimodder
    31 Oct 2007
    Looking good Josh :thumb:
  12. x06jsp
    2 Apr 2007
    Thanks Skullen :D
    Josh
  13. pksjaveed
    pksjaveed Nmodz: modding the world
    28 Apr 2008
    sweet project always loved your polishing on acrylic !!! hey more time at the job means more money !
    more money means more kicka$$ mods!!!
  14. x06jsp
    2 Apr 2007
    Lol Yes it does PKS :D :thumb:
    Josh
  15. Acolyte
    Acolyte What's a Dremel?
    23 Aug 2008
    Like it :)
    Where did you source the ally sheet?
  16. x06jsp
    2 Apr 2007
  17. x06jsp
    2 Apr 2007
    On with the next update :D
    Here is the slot loading dvd drive that i will be using in this case for my girlfriend with the adapder and mounting system attached
    I went over to my local screwfix and picked up some bolts and rivets
    I then got the back mounted on to the case
    Then the window
    I then got around to mounting the dvd drive i clamped the support on the outside and drilled through
    And mounted
    Front cut for the dvd drive
    And mounted :D
    All that is left to do now is mount the feet cut a fan hole in the front and maybe make a fangrill and then sort out mounting for the laptop hdd and drill the hole for the vandal resistant switch :D then its done
    Josh
  18. Tec_
    Tec_ What's a Dremel?
    26 Feb 2008
    **** not another one im not sure if i can handal all the Awesomeness
  19. Mr-IK
    Mr-IK Minimodder
    12 Mar 2007
    Looks like you know how to handle that aluminium :)
  20. x06jsp
    2 Apr 2007
    Lol thanks guys :D
    Josh
