Case Mod - In Progress Project MonoBits (Extreme Prodigy Build) - The case is back to gether 14 Sep 2012
Discussion in 'Project Logs' started by KoSoVaR^, 27 Aug 2012.
  1. modscases.com
    modscases.com What's a Dremel?
    29 Oct 2009
    looking good keep up the good work
  2. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    Thanks! They are lovely ;)
    It will soon be finished :)
    Thank you mate !
  3. KoSoVaR^
    19 Dec 2010
    Hello Guys!
    Sorry for an late update, but better late than never....right ?
    I started to take the case appart more, this time the case feet and handles. They had to be gone becaose of the rivets who are placed behind them and need to be removed so that i can take the bottom piece appart.
    After the drill it looket like this
    Here you can take a look at the simple modification that i did, that piece touched the endtank and didnt let me to allign the rad with the holes, it also didnt let the rad to stay flush with the front. Could you think that a 2mm piece of plate could do such difference?
    White rivets fromMDPC-X, a lot of them !
    Then it was time to rivet everything together, i also did the motherboard tray, went like a charm!
    Something i am doing meanwhile!
    That was the update for tonight everyone :dremel:!
  4. danjw1
    danjw1 What's a Dremel?
    7 Sep 2012
    Are you not putting fans in front of the radiators? Would that push it out enough that is didn't need to modify the case?
    Thank you for the update!
  5. Waynio
    Waynio Relaxing
    20 Aug 2009
    This :) I like your mods KoSoVaR, tidy, nicely coordinated & super nice sleeving. :hip:
    I just go through phases of modding my rear off, vegetating, crazy long times on design tweaks & then having a good browse through the projects I might have missed, this being 1 of a heck of a lot, :D I often rely on MOTM to open my eyes to new projects I miss also. :D
  6. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Weeee! Subbed.
  7. KoSoVaR^
    19 Dec 2010
    The front will be my outtake and there will be enough of flow for that reason :)
    Thanks for the sweet words dude :clap:
    I will do some more and continue with my clean modding very soon!
    Thanks dude, more candy coming soon :D
  8. albert099
    albert099 What's a Dremel?
    19 Sep 2012
    i am expecting a great result from this! subscribed!! :)
  9. KoSoVaR^
    19 Dec 2010
    Im glad to hear that :)
  10. Phyonics
    Phyonics What's a Dremel?
    4 Oct 2011
    Stubbed.
    Excellent progress so far and lot of great attention to detail! I was thinking of getting a Prodigy case when I update my rig next, so I'm following this with interest.
  11. KoSoVaR^
    19 Dec 2010
    Is that a new term ? Naah just jokng...
    Thank you :hip:
    More to come:dremel:
  12. Oso Polar
    Oso Polar What's a Dremel?
    20 Sep 2012
    awesome build!
    I know it is wrong to put pressure on an artist at work but i need a update on this build soon haha :D
    Great job mate! :clap:
  13. KoSoVaR^
    19 Dec 2010
    I will give you an update very soon my friend, i have to work on my office at first :D
    Thank you so much :D
  14. Oso Polar
    20 Sep 2012
    Sounds great! :thumb:
    Btw. On your sketchup model you have replaced the top fan filter with a window. Wont that block the intake of air?
  15. KoSoVaR^
    19 Dec 2010
    Thats just an sketchupmodel, i didnt have the Meshtypes so i just went with what i had :)
  16. Nutman
    21 Oct 2008
    I just had another look at your radiator pics - with the rads sitting that close to each other, you will have problems fitting fans on one of them, or not?
  17. ziza
    ziza What's a Dremel?
    21 Dec 2010
    Bitspower + Prodigy = Amazingness :D
    That acrylic is for the PSU?
  18. wejjy
    wejjy Minimodder
    9 Aug 2010
    Looked at my Prodigy case and looking at where the rads are going to be positioned it looks like there could be issues yes, how are you going to get round this Kos?
  19. LeandroJVarini
    LeandroJVarini Mod is my life!
    25 Dec 2007
    will be a beautiful work!
  20. KoSoVaR^
    19 Dec 2010
    I will describe it down on Wejjy's comment :)
    Yes and Yes :D!
    I have thought about that, and there are two ways that i can choose from, what i will choose is not yet actual, but i will decide soon !
    Thank you !
