Case Mod - In Progress Project MonoBits (Extreme Prodigy Build) - The case is back to gether 14 Sep 2012
Discussion in 'Project Logs' started by KoSoVaR^, 27 Aug 2012.
  1. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    At last update!
    As I longed, I apologize that I could not have done this in the past but have completely honestly been busy.
    I have a large amount of sleevearbaten that must be done before DHW2K12, and it has Sloat down my process for the project when I velar have relatively functional for the event. I hope I can get it together before then, otherwise I just run with my temporary system.
    Aja think about it, this may not be a huge update but I would anyway show what I managed to do so far and I hope that you are content with it :)
    What I had to do is put up a temporary rig for the radiators and there are two steps that I use myself out to get all the dust inside and **** from rescuers (on the inside).
    I started by getting there a little fittings and connect all the radiators in series.
    Besvarar samtidigt en anonym fråga, och svaret är ja moderkortsplåten är lackad på undersidan :)
    The first step is to clean the entire system with warm tap water for 2-3 hours, it is usually enough very well, in the meantime, I took and turned the entire chassis and different directions and shook greatly to get any dirt, metallic particles, solder etc to come off radiator graduated inner walls.
    I also made a small clip where I demonstrate how I set up everything:
    When this part was top, so to speak, I began part two where I do almost the same thing but now I clear my entire system with distilled water, in order that the oxide does not form inside the radiators but also to get a second thorough review out of it all , here I turned on the case, and shook it in the first part out of the treatment.
    What I usually do differently right here is that I use water out of the vacuum cleaner to quickly get out all the water, and I let it on for 1-1.5 hours to ensure that all the water was gone from the radiators.
    Overall, I did so myself of 3L distilled water during the whole process and the clip I show with the little I had saved in a small bottle, vacuum cleaner learn to let some but you see what happens anyway.
    Here's a small clip on the other part out of cleansing:
    As you can see in the pictures it has been almost 90% dry throughout the system and allow it to evaporate the last of the drops, simply as that
    That's all for this time
    Peace out!
    Sincerely
    Venhar Only
    KosovarMods
    Dont forget to spread my facebookgroup!
    I you want to see how MonoBits looked like in dreamhack check my facebookpage :rock:
    KosovarMods
  2. dotdrew
    dotdrew What's a Dremel?
    29 Dec 2011
    Very nice build, love the amount of radiators you managed to fit in such a small space. Can't wait to see the final product!
  3. KoSoVaR^
    19 Dec 2010
    Thank you so much my friend!
  4. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    You should definitely mod your tap to 1/4" dude!
  5. KoSoVaR^
    19 Dec 2010
    haha, gorilla tape work every time :D
