Project: NAS Box
Discussion in 'Project Logs' started by Guest-16, 29 Apr 2006.
  1. z4114
    z4114 FACE!
    25 Jun 2002
    Is the socket that you plug in your AC-DC adpater isolated from the case? Whatever is hitting you shouldn't be volts striaght from the socket. Plug your multimeter into the earthed prong of a power socket and put it on the case to see what voltage is going through it. Then you might get a better idea of where to look.
    :EDIT: If you're not strapped for cash, you could pick up a picoPSU to eliminate the larger exposed PSU. I hope that the 120W it can supply is enough to run the 2 HDDs, board, and processor you have. Plus it's one less thing that will need adequate cooling since those picos are crazy efficient (95% IIRC). You might need a 1 male -> 2 female molex adapter though because I think the pico only has 1 molex plug in it.
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    I bought a 16mm holesaw from Rapid for connectors (£4.11 without arbor) but it's a bit nasty on thin aluminium. I'm wishing I'd paid an extra 82p for a hole punch, they make much cleaner holes.
  3. Guest-16
    Guest-16 Guest
    I bought that 16mm, it's not that bad as long as you drill a pilot hole.
    The PSU plug IS isolated from the case and I just tested it and it is reading 0. :confused: must be the vibrations of the fans.
    If anyone know's where I can get some "industrial" metal buckles, the sort they have on pushchairs or suitcases, I'd like to know.
  4. z4114
    z4114 FACE!
    25 Jun 2002
    Buckles kind of like these?
  5. Guest-16
    Guest-16 Guest
    1st or 2nd one :)
  6. z4114
    z4114 FACE!
    25 Jun 2002
    (you'll have to scroll down a little)
    Click on each picture for the place I found them, but I believe these are US located stores.
  7. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    In which case, check with G-gnome, he might have some spare :D
  8. olly_lewis
    olly_lewis What's a Dremel?
    19 May 2006
    The Silver one, musch better, the metal is cool and sleek while the gild looks like it came from a saxophone case.
  9. Guest-16
    Guest-16 Guest
    Ahh, at "latch".
    So many english words for very similar things.
  10. sk8ter646
    sk8ter646 Minimodder
    4 Oct 2005
    this little mod here is bloody good keep it coming
  11. customh
    customh conflagration.
    22 Oct 2005
    Pretty sweet bindi, i still dont understand the push switch on the front that isnt the power button, the little black one. What does it do? I do like the plug for the network in the back though, very innovative!!
  12. Guest-16
    Guest-16 Guest
    That's on the back, and that's the power plug, CH.
    Or if you mean the hole underneath the push switch, that's just a hole that was already there. You're meant to screw in a, well, screw to hold the lid on.
  13. customh
    22 Oct 2005
    Ok, so wheres the ethernet come in and the power, im missing soemthing.
  14. Guest-16
    Guest-16 Guest
    does this help?
    You might need to ctrl+f5
    For my next trick, I want to get some of those latches for the edge to hold the top down, and cut a hole in the RHS for ventilation. Perhaps using something like this: http://www.mnpctech.com/VGAVent.html
  15. Pygo
    Pygo Rick Relixed
    26 Jan 2003
    Wow, that looks nice there bindi :]
  16. customh
    22 Oct 2005
    Wasnt there a small black in the back?
  17. Jipa
    5 Feb 2004
    Nice collection of fingerprints you have there ;) Bare metal looks cool but is terrible in terms of keeping it clean.
  18. MrSomeone
    MrSomeone What's a Dremel?
    18 Jun 2006
    Looks great.
    Anyone know where I could get an aluminium box like this in the US? I've been looking for a while and can't seem to find anything that's the correct size.
  19. TheoGeo
    TheoGeo What are these goddamn animals?!
    10 Jun 2003
    best trick for that is to give it a good clean then spray on some clear coat.
