Case Mod - In Progress Project: Nexus ITX | A fully watercooled ITX rig | Lian Li PC-Q08
Discussion in 'Project Logs' started by Schaden, 22 Nov 2011.
  1. Schaden
    Schaden What's a Dremel?
    22 Nov 2011
    Nexus ITX
    This project will be coming together over the next month (what a lie), I already have most of my watercooling gear and am only waiting on radiators and my ram/mosfet/chipset waterblocks (these are coming from America).
    Specs
    CPU: 2500k
    GPU: 6950 (unlocked shaders)
    Motherboard: Zotac Z68 ITX WIFI
    RAM: Corsair Vengence 8gb 1600Mhz
    Case: Lian Li PC-Q08
    Watercooling Gear
    CPU: Custom waterblock
    GPU: EK 6970 acrylic top
    Mosfet: Koolance MVR-40 + 67mm plate
    Chipset: Heatkiller NSB Ni
    RAM: Bitspower Universal Module
    Pump: EK 4.0
    Radiators: XSPC EX 240 + 120
  2. Schaden
    22 Nov 2011
    reserved
  3. Schaden
    22 Nov 2011
    Whats done so far:
    and for the hell of it:
  4. Schaden
    22 Nov 2011
    double post >_<
  5. Schaden
    22 Nov 2011
    [​IMG] Stuff has arrived :D
  6. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    nice :), Mini ITX builds is one of my favourites right now :) i will be folowing this one !
  7. KidMod-Southpaw
    28 Sep 2010
    What ******* rated this 1 star? I mean really...
    Great start :thumb: Look forward to more.
  8. Knighthammer
    Knighthammer What's a Dremel?
    18 Feb 2011
    Got the same case - sub'n for sure!
  9. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    Liking what I'm seeing here... Have the same board and was looking to w/c it so I watch you progress with keen interest. I've got a 2600K in mine, but it needs a ridiculous amount of VCore (up to 1.46!) to get to 4.2 Ghz. Might sell on and try another, but for the moment I've changed it to 4.2Ghz @ 1.42 and got a small 40mm fan on the heatpipe as they get ROASTING hot.
    Just had my first crash after it running for 1.5 weeks folding SMP units, so it's looking quite stable enough for me...
    Looking forward to seeing your progress. If the chipset and mosfet blocks don;t need too much modding, then I'll get the same. Need it to be compact as it's going in a recycled Shuttle case.
  10. Combatus
    16 Feb 2009
    +1! Those heatsinks get damn hot don't they? Got a 40mm fan blowing on it for now, but I'll need to sort out some water-cooling when I bung it in my tiny scratch build. Had been looking at the Koolance VRM blocks myself - let us know if the blocks fit okay!
  11. Schaden
    22 Nov 2011
    REVIVAL B*TCHES!
    Okay so this project took a big long break as my itx board died in a watery grave but I now have a new one and a bunch of pics of how it is sitting at the moment :D thought and opinions please!
    all the water stuff that I have to fit in this case.
    the board is running again! (bios problems)
    my gpu waterblock is not looking too pretty and 4 of the bolts holding the acrylic in have seized so there is no chance of me opening the block to clean it. Even some of the nickel has come off and you can see the copper underneath!
    And now for the juicy watercooling pr0n!
    naked
    vreg block
    southbridge
    Cpu block
    might give everything a polish before finishing everything off
    Ram block! Yes I am that silly :D
    Top view to give things a little perspective
    I wont be using the pcie extender in the build, was going to be used for something else so ignore it :p
    The case actually has a fair amount of progress done to it aswell but will take some photos tomorrow after I finish sanding all my filler work!
  12. Schaden
    22 Nov 2011
    Thread Revival!
    I know it has been a long time since anything has happened but the zotac board was not behaving and the bios could not decide what it wanted until a few days ago when I managed to reflash the bios and get it all working again which has kicked me back into gear on working on this build. Tomorrow before work I will work on the case itself a bit and may get a few photos for you guys :D
    Have to fit all this into a tiny pc-q08
    naked board
    vreg
    southbridge
    cpu
    ram (I know :p)
    ignore the pcie extender :D
    Trying to work out the best way for routing tubing and I came up with this.
    note: I don't have the biggest budget that is why I have the random bulky 90 degree adapter and lots of 45 degree adapters as I got them all very cheap in comparison to other 90 degree rotaries which would be cleaner.
    ninja edit: The tubing is old and am only using it to work out how much I will need, will most likely go with clear + mayhems pastel (the tubing was clear but turned pink with pink pastel from a previous build)
  13. Schaden
    22 Nov 2011
    Well I managed to fit all the tubing and main components in the case, just missing hard drives and power cables!
    I still have a fair bit of sanding and boging to do with the case before it is ready for paint but it is looking pretty good! I will be using white acrylic behind the cutouts on the front of the case with leds to illuminate the panel for a mad glow effect.
    cobwebs (its been a while :D)
    I want to find a better position for the pump, but I might need to add a 90degree fitting or 2 in.
    clearance of the block to the psu (was accounted for!)
  14. The_Crapman
    5 Dec 2011
    That's some tight tubing you got going there. You not going to use any clamps? Look forward to seeing what happens with that front panel :)
