Case Mod - In Progress Project: Nvidia Stacker 832 - HDD and Cables - Feb 11th
Discussion in 'Project Logs' started by clownfart, 22 Sep 2008.
  1. clownfart
    clownfart Hardware Enthusiast
    23 Jul 2007
    Intro
    Hello, I've been lurking these forums for a while, and really enjoy what I see. I decided to do a simple case mod.
    About the Mod
    I don't have a big budget, so I decided to do something simple, and something that would give me experience. I've been wanting to do a Warsow mod for a while, but it ended up being too expensive and difficult. I also don't like the devs. :miffed:
    My New Tools :dremel:
    Included Accessories
    First Cut
    Oh No! :confused:
    I can't really get into this spot. Is there an accessory that might be able to help, or should I try the right angle one? And how will I be able to cut out the rest of the logo?
    Wish me luck!
  2. Htr-Labs
    Htr-Labs What's a Dremel?
    16 Jun 2008
  3. Flythe
    Flythe What's a Dremel?
    14 Apr 2007
    Can you reach the spot with a scroll saw?
    Or you could drill two holes and use an jigsaw + file to get a nice straight corner.
    Good luck, your photoshopped pictures looks awesome :D
  4. clownfart
    23 Jul 2007
    Thanks for the comments.
    I don't have a scroll saw, so I'll do the jigsaw method.
  5. r3nesis
    r3nesis What's a Dremel?
    1 Aug 2008
    why dont u try to cut it from outside..i think it will b easier but u have to draw a new one..
  6. The boy 4rm oz
    10 Apr 2008
    Good start, I'll be watching.
  7. clownfart
    23 Jul 2007
    New parts!
    Two EVGA GTX 260 Core 216 SCs, a Noctua NH-U12P, an NF-P12 (already owned, for push/pull), an NF-B9 (for retired 8800 GT with HR-03 GT), and four NF-S12s.
    A Successful Upgrade
    I also flipped the mobo tray, cause this case is awesome. The cabling is kinda whack right now.
    Theres also been progress on the cut out, but I don't have pics yet. :(
  8. The boy 4rm oz
    10 Apr 2008
    Nice gear, you packed a lot into there lol.
  9. pizan
    pizan that's n00b-tastic
    25 Apr 2008
    Isn't it supposed to be Before then After?:lol: But nice parts and nice work
    I didn't see the question about the cut until now, but a Dremel flexi shaft attachment might help out with it or possibly a bigger diameter cutting disc? Good luck
  10. clownfart
    23 Jul 2007
    More Cutting
    Door Thickness
    About 3mm.
  11. ry@n
    ry@n Minimodder
    31 Aug 2005
    I love the look of a nicely packed case :)
    Goodluck with that detailed cutting and sweet username lol
  12. slackerXL
    slackerXL www.SlackerXL.com
    13 Jun 2005
    you're using a wrong disk for cutting such thick aluminum.
    you should use one of these
    they cut much faster and are far more durable
    or the plain ones (non speed-click system)
    some tight spots can be trimmed with a vertical cutting tool like this
    and when you finish with the big rough cuts
    get yourself a set of small files to sharpen the corners and smooth the edges
    also i'd suggest dissasembling the fans and painting them...
    brown and ivory don't really match with the nVidia green
    unless you're drawing trees on a piece of paper
    I think a black-green pattern like the nanoxia fans would be much better
    good luck with the rest
  13. Nolimited
    Nolimited What's a Dremel?
    12 May 2008
    Nice hardware selections, not easy to cut 3mm keep it up man :thumb:
  14. clownfart
    23 Jul 2007
    Thank you very much for that post. :)
    I bought some disks similar to those a while back, but I wasn't using them because they're off centered and wobble a lot. I'll get the ezlock ones since they probably wont wobble.
    I also bough a couple cutting bits. One like the one you posted and one kinda like this which is working better for me:
    I haven't found a small file set at any hardware store, and I looked a long time ago at a few hobby shops for my hobby and never found any. I'll try and look online for some, it would definitely help.
    I was planing on painting them, but not disassembling them. I saw those fans a while back before they were released and I couldn't remember the name. I Probably going to use those on the window.
  15. jhanlon303
    7 Sep 2006
    It would help us all with suggesting tools and suppliers if you tell us where you are. We have users from Malaysia to the Ukraine. Pick a place - somebody here can help you source affordable tools.
    john
  16. clownfart
    23 Jul 2007
    I'm from Calgary, AB in Canada.
  17. jhanlon303
    7 Sep 2006
    Thanks! Langer and several others are fom Canada and there are actually quite a few of us from the US even if the website is UK based.
    john
  18. clownfart
    23 Jul 2007
    Ordered some LC!
    Swiftech APOGEE GTZ
    2x D-TEK Customs Fuzion GFX V2
    2x D-TEK Customs UNI-SINK
    Swiftech MCP655
    Feser One X-360 TFC Xchanger
    Tygon1/2" ID 3/4" OD
    Feser One Fluid UV Acid Green
    Swiftech MCRES-MICRO REV2
    How does that setup look?
  19. clownfart
    23 Jul 2007
    Lol, forgot to get the mounting brackets for the GPUs. Costs me $25. :(
  20. The boy 4rm oz
    10 Apr 2008
    The loop would look better if you went from GPU to GPU instead of splitting the line.
