Case Mod - In Progress Project : PURE "FINISHED"
Discussion in 'Project Logs' started by subset7, 22 Mar 2009.
  1. Denrik
    Denrik What's a Dremel?
    2 Mar 2009
    Great colour scheme mate, looks really clean and thought out. Hope the rest works out as well.
    Dan.
  2. Mokey Mokey
    Mokey Mokey What's a Dremel?
    9 Mar 2009
    This is pure sex! Those reservoirs are hot! :blush:
  3. wgy
    wgy What's a Dremel?
    28 Jul 2008
    now thats pure. :blush:
    good job man, looks awesome.
  4. Spyrious
    Spyrious Modding all the Time
    8 Dec 2008
    Excellent work.I like the white and black very much.Keep up.
  5. ry@n
    ry@n Minimodder
    31 Aug 2005
    The black and white theme is clearly a winner! Very, very nice mate.
    Where did you get your Bitspower stuff from? I need some 45 elbows for my project :)
  6. subset7
    subset7 Spanking the Monkey
    31 Aug 2008
  7. subset7
    31 Aug 2008
    I thought i'd make a fan filter for the PA120.3,this is it so far
    Just need to spray it up and attach the mesh
    I also made a rough test rig for testing on air first
    It's a bit rough but should do the job and i'll be able to keep everything together if I need to move it,i'll fit a small loop for the GTX 280 H2OC aswell
  8. subset7
    31 Aug 2008
    Here it is with the loop fitted
    I'll try and get it up and running during the week.
  9. Han$en
    Han$en Skulltrail!
    26 Mar 2009
    Sub'ed..
    Looks good so far :):rock:
  10. Stickeh
    Stickeh Help me , Help you.
    20 Jul 2003
    Love the look of this, the colour scheme is awesome.
  11. B4TM4N
    B4TM4N Ninja
    11 Aug 2008
    Mad wood working skills.
    That case is what i would like to do onetime
    Is there fans underneath for cooling the harddrives though?
  12. Odin Eidolon
    Odin Eidolon What's a Dremel?
    7 Feb 2009
    "Pure" is the right name for sure. subsd!
  13. subset7
    31 Aug 2008
    It's only for testing before I fit the mobo blocks etc, though I will stick a fan in the bottom blowing over the HD's.
  14. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    I like where this is going with the black and white.
  15. jegerjon
    jegerjon What's a Dremel?
    10 Jan 2007
    Sweet colors! It looks very clean :)
  16. subset7
    31 Aug 2008
    Just a small update,finished the dust filter for the PA120.3
    Fitted to the rad
    I'll try and get more done over the weekend.
  17. subset7
    31 Aug 2008
    Leak testing
    2 hours,so far so good.
  18. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    wow this is looking truly awesome! can I ask what you used for the fan filter mesh?
  19. subset7
    31 Aug 2008
    It's diffuser used in TV lighting,works really well and is very flexible,I just double sided taped it to the back.
  20. Mokey Mokey
    9 Mar 2009
    Fantastic filter, adds to the overall sexiness of the case.
