Project: Puzzlebox Pc (10/09) COMPLETED!!
Discussion in 'Project Logs' started by [WP@]WOLVERINE, 14 Aug 2004.
  1. Chiron
    Chiron What's a Dremel?
    2 Sep 2004
    :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop:
    that's the sickest and coolest idea I have ever heard of :D I've seen mods involving mannequin heads and stuff, but most of them were pretty awful to look at
    don't you have problems fitting it inside, considering the size of such a mannequin head?
  2. [WP@]WOLVERINE
    [WP@]WOLVERINE What's a Dremel?
    18 Oct 2003
    I actually havent got the head yet its due to arrive tomorrow, but if its too big then ill just mod it :D theres nothing thats goinig to stop me getting pinhead in there :D
  3. Chiron
    2 Sep 2004
    that's what I want to hear :D
    you might want to add some kind of strobe on the inside that fires a couple of flashes at random so you can see the head flashing with a lightning effect from the inside, just to scare off nosy people at exhibitions :naughty:
  4. Zion
    Zion What's a Dremel?
    11 Apr 2004
    just one word... Sexy :naughty:
  5. [WP@]WOLVERINE
    18 Oct 2003
    -=UPDATE=-
    I finally got my manequinhead today and went straight to work on it
    Heres a picture of the victim and some of my instruments of torture :D
    First some basic color
    Then some lines
    And finally a testfit of the things that make Pinhead a Pinhead :D
    Theres still tons of sanding,painting,cutting and shaping before ive got a goodlooking replica. But ill get there :) More updates will come soon :D
  6. hmekk
    hmekk What's a Dremel?
    17 Jul 2004
    cool and creepy :hip:
  7. Chiron
    2 Sep 2004
    awesome.. but the head is 'smiling' :D are you planning to do something about that?
  8. z\\\\ffs
    z\\\\ffs What's a Dremel?
    2 Aug 2004
    damn nice!i love this mod!
    :rock:
  9. hilmana
    hilmana What's a Dremel?
    20 Aug 2004
    well i have one thing to say
    GOOD LUCK in your mod
  10. Andersen
    Andersen Morally questionable and ethically wiggly
    25 Nov 2002
    Is it just me or do those nails look rather large?
    IIRC Pinhead had much smaller nails in Hellraiser. I could grab some screenies off Hellraiser DVD if someone could tell me why WinDVD can't take screenshots.
    Looking mighty fine otherwise. :thumb:
  11. dom_
    dom_ --->
    4 Jan 2004
    anderson right click on film area, bookmark/capture. then go from their
  12. buchans
    buchans What's a Dremel?
    28 Jun 2004
    looking good - will be very interesting to see how how this turns out
  13. [WP@]WOLVERINE
    18 Oct 2003
    -=Update=-
    Time for a testfit of pinhead inside the case. In normal mod the cube is completely black and you cant see him, but with a little red light he becomes visible
    The effekt when the room is totally dark is amazing, it turned out far beyond anything id hoped for. One evil lookin dude inside my case dont ya think :D
    As many has pointed out to me i went a bit berserk with the nails on the first test but that has been fixed i removed the nails around the eyes,mouth and ears so it looks as it should
    Theres more to come....
  14. DrPepper
    DrPepper What's a Dremel?
    26 Aug 2004
    Try:
    Code:
    <a href="http://forums.bit-tech.net/showthread.php?
    t=46844&highlight=blacklight+demons">Blacklight+demons</a>
    You will get a link instead of text?
  15. Godboy_g
    Godboy_g What's a Dremel?
    13 Aug 2004
    Man, this mod ROCKS!!
    One question though... How much "headroom" :D do you have in the case?
    Does it clear the Mobo, or did you have to hollow the back out a bit?
  16. [WP@]WOLVERINE
    18 Oct 2003
    I havent got to that stage yet but im shure that there vill have to be som hollowing because theres no way it will all fit otherwise :)
  17. buchans
    28 Jun 2004
    WOW that rules! :rock:
  18. crash32953295@msn.
    crash32953295@msn. What's a Dremel?
    2 Aug 2004
    I would jus like to say that frigin rocks :rock: :rock: :rock: . just imagine if some burgular walked in and saw it hed be running for miles hehe.
  19. Dmc
    Dmc Minimodder
    13 Jul 2004
    Man oh man what goes on in your head :D Truely a thin line between madness and a genius, this mod is the bomb :thumb:
  20. [WP@]WOLVERINE
    18 Oct 2003
    -=UPDATE=-
    Today i did a first test with all the hardware in place. I also scrapped the whole metalframe idea and insted i put the cube together with chemical steel, that stuff is truly amazing. I got a much better look with the chemical steel because i could get rounded edges wery easy. It was really easy to apply and the cube is solid as a rock :) Heres some pictures of the cube in action for the first time as a working system.
    And of course a nightshot :D
    Theres still alot of work to be done with Lightning,Fans,Power/reset buttons,Remote control and the base itself. But im getting there :)
