Project PX03 Darkcrystal wOOdcase FINAL PICS
Discussion in 'Project Logs' started by piloux, 12 Nov 2003.
  1. piloux
    piloux What's a Dremel?
    12 Nov 2003
    i found these in my grandfather's workshop
    it must be older than I :lol:
  2. broots
    broots What's a Dremel?
    24 Sep 2003
    Excellent
    I must give you my congrats on excellent work!
    Just when I thought I'd seen almost every possible "casemod" you come along with something I've never seen before! Great idea and excellent work on the case! I also admire your work with fabricating your own parts!
    The look of your junction box is very cool, I think the case would look awesome with that same finish!
    :thumb: :dremel:
  3. piloux
    12 Nov 2003
    thank you very much for comments guy :) , i had finished the back of the case and left window too but i was tired yesterday and holidays are finicshed for me now , well it s time to go to work may be i ll post some pics tonigh or tommorrow if i ve got any time ;)
  4. dagamore
    dagamore What's a Dremel?
    2 Nov 2002
    except for the post I cant read (hey I am a yank I barely read English :p) I am blow away with this mod, one of the best and most original I have seen in a long time, the level of work just blows me away. I would rank this right up there with ZapWizzards ammo case mod, and the Gnomes ORCA'3 mods. I am just blown away with the level of work, and the thought that you had to put in to it.
    :jawdrop: :jawdrop: :jawdrop: :rock: :rock: :rock: :clap: :clap: :clap:
  5. tomek
    tomek What's a Dremel?
    7 Nov 2003
    Hello
    Nice mod.
    Bardzo fajne po³¹czenie drewna z Plexiglasem.
    Jako gor¹cy fan obudów z drewna przygl¹dam siê z zainteresowaniem Twoim poczynaniom.
    Question: why is your case so big. I preffer case small as it can be.
    Good Work, I like it.
    Tomek
  6. The_Resetter
    The_Resetter I LIKE CAKE!
    6 Oct 2003
  7. piloux
    12 Nov 2003
    resetter> may be it s possible i dont know or you can search shop which exclusively sells gummy articles
    tomek> the case is not so big, its mesurements are 51cm /47cm/22cm (i dont know how much inches it is :confused: )
    thanks for comments it's really gratifiant for me :)
    well new pics of my work :D
    the junction box and appearance I m going to give all cables which will not hide, the red thermo will be replace by black one i have to buy
    I m searching for others screw to shut the box...
    this is the hole for the cables coming from double ground and entering junctin box and the half hole is for cables coming from powersupplies and descending behind motherboard
    thats the system i made to hide the // lcd cable: hide by motherboard and going through backside of case betwwen pci'sopen and case
  8. piloux
    12 Nov 2003
    then I had cut the backside panel, it s made with two lexan pieces: one to hold the fan and the grill , one to give a good exterior finished
    and the panel to shut ground case
    hole to fix the panel
    hole for extract fan
    the panel is screwed to case
  9. FlashPanHunter
    FlashPanHunter What's a Dremel?
    22 Aug 2003
    Looking good, I cant wait for when it is time to remove all of the masking tape, Its going to look awsome. Are you polishing the edges of the plexi?
    Sorry, didn't see you were still updating. Looks awesome, great job on the hole in the plexi.
  10. piloux
    12 Nov 2003
    the exterior fan hole
    I polished it with this
    good work :) but i wondered myself how I will going to fix the pci cards because there is not enough place to put screw on it then i decide to use thumbscrews but i had then to make place for it and that will be next update :D
  11. piloux
    12 Nov 2003
    I cant wait too :D yes i ll plished every edges , i will do this during the painting
  12. Gedron
    Gedron What's a Dremel?
    31 Oct 2003
    Perhaps you could use an angle pracket to run along the tops of the PCI slots. Then you could "thumbscrew" that into the case. It would keep the PCI cards from coming out. Many cases from retail outlets like Dell and Gateway use a method like that. I'm trying to find an image of what I'm talking about, but not having much luck yet. I'll post it up if I come across one.
  13. piloux
    12 Nov 2003
    thank you very much i see exactly what you re thniking, I ll think about it :)
  14. tomek
    7 Nov 2003
    I haven't seen so nice case for very log time.
    I can't wait to see more pictures.
    I also want to show you something, maby it helps You to find another intersting conclusions.
    http://www.moded-kompz.net/?name=Projects&id=7
    It isn's so advanced as yours, but...it's small :)
    Keep it up.
  15. MaxWiz
    MaxWiz What's a Dremel?
    1 Oct 2003
    tomek - Thats not a small wooden case. This is a small one.
    And it has a built in sound system!!!!!
    The linky
    Max :D
  16. MaxWiz
    1 Oct 2003
    Oh, should have said this too
    piloux - your case is EXCELLENT :jawdrop:
    Max
  17. tomek
    7 Nov 2003
    I know, i know...
    But, mine case is based on standard MicroATX components. I can replace everything without drilling and cutting. :rock:
    Prime directive: use standard components to change entire configuration.
    Thit case is 3 years old. :cooldude:
    Now I have a newHDD, CD-RW, VGA, front panel.
    Tomek
  18. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Cut the hijacking OK? He is building a magnificent case and you are argueing over other wooden cases, no need for that...
  19. KinGvsKinG
    KinGvsKinG What's a Dremel?
    20 Apr 2003
    :jawdrop: that is one sweet looking case. :rock: GREAT job, piloux!
  20. piloux
    12 Nov 2003
    well it s clear that my case is bigger than these but my thought was to build a desktop tower for the atx norm, may be i ll build another one more little when this project will be finished... moreover my desk is very large :D
    im very happy there are lot of people who love my work :)
    my today work : I haven t work a lot but I think you are interesting by the continuation :
    I have cut the corner of backside panel
    I thought about the screws for pci slot and found solution:
    I used this skill :
    and I work with it on the plexi in front of each pci slot
    that's the result :
    now I can easily screw into pci slot with my hand :)
    here is the cutting of left window, it s made of lexan like the all pieces but I wonder myself if i will changed later for colour acrilic?
    I cut it with hacksaw
    I havent work on it any more, i will have to adjust this and then polish the edge
    that goes on :) :dremel:
