Case Mod - Complete Project: Raptor Lake
Discussion in 'Project Logs' started by samarlian, 10 Sep 2022.
  1. samarlian
    samarlian Minimodder
    8 Aug 2018
    Massive thanks to Intel for asking me to do a build for them.
    System Specs
    • 1 x Intel cpu under NDA
    • 1 x ASUS ROG STRIX Z690 -E GAMING WIFI
    • 1 X ASUS TUF GAMING RTX3090 OC 24GB
    • 2 x Corsair Dominator Platinum RGB DDR5 5200MHz 32DGB
    • 1 X Corsair HX1200w PSU
    • 1 x Samsung 980 PRO 2TB M.2 NVMe
    • 1 X EK Quantum Velocity CPU Block and backplate
    • 1 x EK Quantum Vector RTX3090 Block
    • 1 x EK Quantum Kinetic 360 D5-Distro
    • 2 x EK Quantum Surface S360 radiator
    • 10 x EK Quantum Torque fittings
    • 16 x EK Quantum Torque 90 degree fittings
    • 4 x EK Quantum Torque 45 degree fittings
    • 8 x EK Quantum Torque rotary offset
    • 6 x EK Varder X3M D-RGB fans
    • 2 x EK Cryofuel Navy Blue
    • 1 x Antec Cannon case
  2. samarlian
    8 Aug 2018
    panels preped and painted
    [​IMG] [​IMG]
    The_Crapman likes this.
  3. samarlian
    8 Aug 2018
    ASUS TUFRTX3090 stripped cleaned off excess TP and fitted EK Gpu block
  4. samarlian
    8 Aug 2018
    Custom vinyl applied
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    douglas alves and Cheapskate like this.
  5. Cheapskate
    13 May 2007
    Neat!
    The color choice bugs me for the simple reason that it looks like painter's tape. 3M ruined a perfectly good color.
  6. samarlian
    8 Aug 2018
    Its designed as intel blue caution tape once build is complete will come apparant
    Arboreal likes this.
  7. samarlian
    8 Aug 2018
    case coming together , panels left to weather and add grime to look distressed same as vinyl.
  8. samarlian
    8 Aug 2018
    Been pushing it hard last 2 days, just tubing left to do, leak test make a panel to cover cables under the distro and add final touches.
    [​IMG] [​IMG]
    Cheapskate likes this.
  9. samarlian
    8 Aug 2018
    Bends done and leak tested and panels weathered
  10. Cheapskate
    13 May 2007
    Tastefully balanced paint. :D Love the tubing runs too. I wonder how it would look with blue on the sides of the radiator peeking through the panel cutouts.
  11. samarlian
    8 Aug 2018
    thanks and great idea for side of rads
  12. samarlian
    8 Aug 2018
    Leak test done pull it apart and add NDA cpu and add final touches
  13. censored_Prometheus_
    censored_Prometheus_ Minimodder
    26 Mar 2019
  14. samarlian
    8 Aug 2018
    Final photos of Raptor Lake build for Intel with a 13900K
  15. samarlian
    8 Aug 2018
    Few more pictures before i pack this beast up for delivery to Intel UK tomorrow
  16. Cheapskate
    13 May 2007
    Great final result. :D
    We have problems with lizards getting stuck in things here too. Poor guy.
  17. samarlian
    8 Aug 2018
    lol
