Project: Satan's Deuce
Discussion in 'Project Logs' started by bonzanego, 27 May 2005.
  1. Cowinacape
    Cowinacape What's a Dremel?
    26 May 2003
    Holy crap batman! Excellent work there guy, very original, and very very slick! Thumbs up to your grand-dad for lending a helping hand as well.
  2. Uno1_
    Uno1_ What's a Dremel?
    14 Nov 2003
    Ambitious and delicious! Are you going to be cutting out segments of the mobo plate to allow the mobo back to been seen through the second window? It'd be a shame to just have plain metal showing through those flames.
  3. drinn
    drinn What's a Dremel?
    16 Jul 2004
    That's nice! Like your design :)
    Btw, black & white images are not so good in your first post
    However I'll be watching this project
    Good luck!
  4. jackjr
    jackjr What's a Dremel?
    27 May 2005
    I'm loving this mod.. subscribed. Just curious, where did you find that fan grill?
  5. arkadur
    arkadur What's a Dremel?
    3 May 2005
    you got it man.. :)
    keep modding
    what are you plan now?
  6. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    the grill will look absolutely fantastic when it's finished...superb job with the front part and the hinges...can I borrow your grandfather sometime :p
  7. bahgger
    bahgger Minimodder
    13 Apr 2005
    Top notch stuff I really really like this :) I consider this one of my favourites right now :)
  8. Kumo
    Kumo What's a Dremel?
    18 Oct 2004
    You know i love your work. That isn`t a exception.
  9. Gioz
    Gioz What's a Dremel?
    21 May 2005
    WoooW
  10. Isuo
    Isuo What's a Dremel?
    13 Oct 2004
    Really cool!
  11. bonzanego
    bonzanego What's a Dremel?
    5 May 2005
    I have actually decided to leave the other panel solid, it occured to me that if you wanted to hide the wires behind the mobo plate, cutting out the panel would blow that deal.
  12. bonzanego
    5 May 2005
    I made the fan grill, I own a company called Bonzai-mods, we design and sell fan grills of all kinds, this face one is my company logo.
    Thanks everyone for all the kind words, I will be shooting the paint for this case in the next few days, I am going for a classic black with warm colored flames, i.e. a fade from white at the front of the bezel into yellows, reds and oranges. I am undecided if i will use flat black (the classic primer look) or clearcoat the whole thing. I will also be gutting the twin 80mm intake fans up front and putting in a cleaner single 120mm intake fan.
  13. turboturtle
    turboturtle What's a Dremel?
    10 Jan 2005
    I dont often post, but I just had to say that I can't get enough of this case - Excellent idea, excellent work and i am fully impressed with the way this is going! Well done, and I hope to see many updates :)
  14. Guest-6374
    Guest-6374 Guest
    I think the glossy black would match the flames the best. If you have half-gloss and half-matte it will look strange, and it would definitely look better shiny.
    Fantastic work on that door. I don't think I've ever seen a thread hit 5 stars so fast.
  15. IYIENACE
    IYIENACE What's a Dremel?
    30 May 2004
    It looks like for the front "scoop/grill" that you used sections of styling foam and then coated them in resin before filler?
    Looks nice, and I like the fact that you use guide coats - most don't understand the importance. :dremel:
  16. luvbug
    luvbug What's a Dremel?
    22 Sep 2003
    I have to agree with the glossy black... While primer might look ok on a car, I don't think the mod would suffer from a gloss finish... it might from a 'primer' flat black finish.
    luvbug
  17. macncheese
    macncheese What's a Dremel?
    25 May 2005
    Excellent project. I've got some similar ideas in my sketchbook and you're really inspiring me.
    I vote satin black, it really makes the flames pop. Respect to the old school! :thumb:
    Cheese
  18. bonzanego
    5 May 2005
    The original bezel is fiberglassed foam core like a surfboard covered in a home-made filler, However that would not be nearly heavy or strong enough to handle years of use so I actually molded a copy of the original Fiberglass/foam part. It is cast in solid urethane plastic.
  19. H311R4153R
    H311R4153R What's a Dremel?
    28 Mar 2005
    That looks very good :rock: , nice project.
  20. mandy_modded
    mandy_modded Minimodder
    12 Mar 2005
    excellent,
    I have several 1948 Wolseleys (UK built so not hotrod's), and i might have to do something like this, but made to look like a Wols grille & hood.
