Project: Sli 'n' Shiny Wavemaster
Discussion in 'Project Logs' started by coolmiester, 16 Feb 2005.
  1. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    Oh yeah there is one final thing and that's the fan grill which i must admit i had problems with but it looks like it should be complete soon.......just deciding on the font to use on the logo to let as much air through as possible.
    They are laser cut and being made from polished stainless steel and will look similar to in the picture below......obviously it will be a double grill.
    On a side note, i've not been idol but been researching parts for my next project which should start comming together pretty soon
  2. Dekode
    Dekode What's a Dremel?
    28 May 2005
    That PSI meter, where can ya get them from?
  3. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    From here :D
  4. waitandbleed
    waitandbleed What's a Dremel?
    4 Feb 2005
    Thats such a sexy case! Nice job! Nice idea w/ the watercooling! Glad to see the wavemaster being modded! This is the case I want to get and mod :rock: cept mine will be black :D Once again nice job!
  5. coolmiester
    31 Dec 2002
    Cheers waitandbleed........you mean black like this one
    Ventmaster log >>here<<
  6. angelorus2000
    angelorus2000 What's a Dremel?
    14 Nov 2003
    i love the shiny metal
    mod on :rock: :rock:
  7. Byron
    Byron What's a Dremel?
    27 Aug 2004
    brilliant job coolmiester! :thumb:
    i've one question, how do you polish all the metalic parts btw? could you give us a guide or something?
    Cheers,
    B
  8. coolmiester
    31 Dec 2002
    Appreciated Byron.....cheers :thumb:
    I never actually got round to putting it down in writing but the best, recent polishing article that i've come across lately which covers most things is this one from Metku Mods
    Its only a small article and well worth a read but i've said it before and i'll say it again...........its a dirty horrible time consuming job but the results speak for themselves.
    Hope the link helps
    ....... i couldn't resist another picture :D
  9. Byron
    27 Aug 2004
    very good link indeed, thanks for that ;)
    now another question came up... how the bloody ell u managed to lap these buttons of the fan controller?!?! :D
    and also, can you polish plastic? or is it duable to metalic surfaces only?
    Ta,
    B
  10. coolmiester
    31 Dec 2002
    LOL.........aluminium is a great metal to work with as its so soft so it doesn't really take that much doing to get it nice and shiny.
    For small stuff like the controller knobs i use a bench grinder fitted with a polishing mop to one end so as long as you got asbestos fingers you can polish all day :D
    Polishing plastic won't really work but you can get plastic chromed if that's any good
  11. Byron
    27 Aug 2004
    :D
    aye, thanks coolmiester, keep up the good work and white fingers :rock:
  12. ShinySwede
    ShinySwede What's a Dremel?
    6 May 2005
    Dirty and horrible ...right on target =) ...if i only knew what i was getting myself into =P.......And yes the aluminum is very soft indeed , the only downside is that the anodisation is rock hard =( so when you cut through that with the machine on a few places your bound to to the rest by hand or you´ll have an un even surfice =/......
  13. coolmiester
    31 Dec 2002
    Eventually started marking out for a custom flame grill for this case.
    Its going to be hand cut from 3mm aluminium plate which will obviously be polished once its all cut out so should look quite good providing all goes well.
    I first marked out the edge using the BIX shroud for a guide and then added some flames using one of mnpctechs flame stencils for reference..........thanks if you see this :thumb:
    It'll do nothing for air flow but that was never the priority.......look good function second :)
    It will take quite a while so don't expect it finished tonight :eek:
    BTW, it's the black bits that get cut out :)
    Managed to get all the cutting done using a fret saw with the tiniest little 18tpi blades which was good fun so its just a case of filing the corners round and polishing the whole thing to match the shiny case.
  14. Gnemelf
    Gnemelf Minimodder
    9 Aug 2003
    love that grill
  15. -Erik-
    -Erik- Guest
    You've out done urself this time. That looks amazing!
  16. fohkus
    fohkus What's a Dremel?
    12 May 2002
    wow damn. how does a fret saw work? Just like a normal saw? Manual hand labor???? :D
  17. coolmiester
    31 Dec 2002
    Cheers for that :thumb:
    Managed to get the grill polished using Peek and my trusty DA Polisher and then fitted so loads of pictures :cool:
    All im waiting for now is the release of the NV-78 blocks to plumb in the GFX cards
  18. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    That is bloody sweet.
    Nicest case you've made to date IMO.
  19. koola
    koola Minimodder
    11 Jul 2004
    Agreed. Sweeeeeet!
    Nice job :thumb:
  20. slaw
    slaw At Argos buying "gold"
    13 Feb 2003
    NIce!!! very original
