Project: Sli 'n' Shiny Wavemaster
Discussion in 'Project Logs' started by coolmiester, 16 Feb 2005.
  1. sc4mpi
    sc4mpi OG watercooler
    16 Jan 2005
    or you could get a pcp&c 510 sli and crome it up :p
    Since u have Cash to splash (y do things by halfs :hehe: )
  2. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    looks amazing paul
    Can't wait to see it rigged up
    - S
  3. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    Cheers for the info on the PSU's.............ended up getting another Enermax 600watt Noisetaker with 2x PCI-E power connectors (same model as before but this one has 2 :confused: ) Plus it has the intake fan on the base which won't get restricted when the dual 120 BIX goes in.
    Anyway.....got the cards fitted to the blocks (which is quite a job in itself) and then a dry run at seeing how the pipe work is going to fit best.
    Think i've got it just about right as there is quite a bit of hose to get into a Wavemaster - the loop will go...
    Pump>>>NV-68(1)>>>NV-68(2)>>>CPU>>>Chipset>>>Radiator>>>Res>>>Pump
  4. Mayo
    Mayo What's a Dremel?
    7 Sep 2004
    nice job!!
  5. jopers1986
    jopers1986 Minimodder
    7 Jan 2005
    looks amazing! ace job, it's all looks a little tight tho with the NB from the CPU!
    can't wait to see the whole job finished! :D
  6. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    oooo that's some tasty pipework. :hip:
    *starts chant* fill fill fill fill :D
  7. OneMadPoptart
    OneMadPoptart What's a Dremel?
    14 Oct 2003
    Mmmmm very tasty. Love the simple tubing layout. Have any more pics from a little farther away?
    Cheers.
    -OMP
    (BTW -- Only the copper TDX? I would think someone such as yourself would instantly put in the silver variant :D )
  8. Kipman725
    Kipman725 When did I get a custom title!?!
    1 Nov 2004
    Is your water cooling all in one loop?
    If so don't you have flow dificulties?
  9. Rich_13
    Rich_13 What's a Dremel?
    12 Feb 2003
    that does seem like a lot for one loop, no doubt you have a pretty powerful pump :)
  10. Firehed
    15 Feb 2004
    I'd like to see an overall shot of the case with the w/c stuff installed, but looks very nice! I'm not going to try thinking how nasty it must have been getting that 2" piece of tubing between the cards... granted I'm sure you were smart enough to do that out of the case/mobo.
  11. jazzzyj
    jazzzyj Minimodder
    2 Apr 2002
    Just thinking out loud here... but you see where you have the wee little pipe.. what if you had a flow meter in there somehow.. maybe so it connects the 2 blocks? Thinking about it, it would be a biatch to plumb though.
    -J
  12. coolmiester
    31 Dec 2002
    Little bit of an update....
    got my hands on a Coolermaster front bezel to hide the beige CD Rom and polished it which turned out quite well.
    I've also got the 2 Sli cards up and running but no benchmark as yet as i'm still trying different drivers and mainly concentrating on getting the case finished.
    I'm using and un-modded DDC pump and even with the 2 Sli blocks and also a chipset and CPU block it is still pushing out 3 PSI (not had a problem with this pump not starting yet bit it is one of the older versions and keeping a close eye on it)
    BTW....cards are running at 39 and 40 degrees
    A few pictures anyway...
  13. Tim S
    Tim S OG
    8 Nov 2001
    sick dude :rock:
  14. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    Wicked sick :rock: :D
  15. rob_65
    rob_65 What's a Dremel?
    5 Apr 2004
    Looking absolutely fantastic..
    You've gone to great detail with this, and it really does show in the photos :)
    Keep up the great work!
  16. Leeum
    16 Feb 2004
    Holy moly :jawdrop: This is amazing work, keep it up :D Starts another chant, LED mod those blocks, LED mod :D
  17. G4m3R_X3r0
    G4m3R_X3r0 What's a Dremel?
    3 Sep 2004
    That looks sweet!
  18. coolmiester
    31 Dec 2002
    Woah.......don't usually see you in here bigz :hip:
    Don't suppose you know which drivers will be best for these cards???
    Cheers guys..........believe me there is a lot of work gone into this one and pictures are never going to do it justice so its going on the road this year to as many shows as i can squeeze in :naughty:
  19. Tech-Daddy
    Tech-Daddy What's a Dremel?
    8 Oct 2003
    Astoundingly clean and professional!
    Truly efficient. Well thought out!
    :clap: :clap: :clap: :clap: :clap: :clap:
  20. Tim S
    Tim S OG
    8 Nov 2001
    I pop in and have a read every now and again when I'm waiting for windows to install :hip:
    Have you tried 71.84 yet? Although there are reported problems with overclocking in SLI - I'll have to investigate that later this week myself, but Firehed was reporting issues with them. They certainly have the widest range of games supporting, so if you can find a driver build with a date after the date on 71.84, you will likely find the features/support of 71.84 with overclocking and also performance improvements (one would hope!).
