Scratch Build – In Progress Project Stealthlow - Completed - preview of project next
Discussion in 'Project Logs' started by Waynio, 30 Nov 2010.
  1. Waynio
    Waynio Relaxing
    20 Aug 2009
    It's been an up & down year for life but for modding it's been goooood, interesting, frustrating but most of all satisfying & fun & that lifts the blues nicely, thanks GNU :D:clap:.
    Freshly thought of, designed, printed & cut pieces for the sata data cable casing, now it's time to bend them :D.
  2. Cleveland216
    Cleveland216 Carbon Fiber King
    30 Dec 2007
    Cable management is always a pain!! Very clean wrapping, though, I would have tucked them in tighter, like closer together somehow. You should make a copper conduit piece to hidden all the wires. That would look pretty awesome, keep up the good work.
  3. Waynio
    Waynio Relaxing
    20 Aug 2009
    Cheers Cleveland216 :) got it all figured out, adjusted 2 of the clips I had spare which hold it all in better & working on the sata data cable tidy case :).
    I would have had something pretty sweet to show today but found I have run out of epoxy resin :(:lol: so had to call it a day after searching all over the garage for adhesives.
    While I'm out posting KidMods fan bits I'll pop around to B&Q to find a quality strong adhesive, all the bending is done though & all the pieces are brushed, it basically is conduit but fancy conduit :D should look nice & in tune with the theme.
    Caught I think my first cut of the mod during making this update :lol: was cutting an extra piece to aid in placing the bits spot on & the blade worn out & broke, turned it off & gave the sheet alu a fast wipe with my hand & it felt bad like I just dug in & slashed myself with a razer or something, looked at my hand & part of the blade had dug itself right into my finger about 8mm in with a couple of mm hanging out with the teeth going in the worse way to pull out :lol: so carefully yanked it out :lol: & cleaned it up, damnit thought I'd get through this unscathed :D but near the begining of this log I dropped a vice on my foot but very luckily just had a very sore foot for a while I'm amazed I didn't bust my foot properly from that :D.
    Got some epoxy resin & posted KidMods fan bits :D now it's time to pick up where I left it :).
  4. Waynio
    Waynio Relaxing
    20 Aug 2009
    Wooo hooo got the epoxy resin, I went for 1 I've used before & has proven it's worth (araldite rapid steel) since there was no JB weld at B&Q lol I almost bought a tube of liquid metal but I figured with such a huge amount of adhesive for only £3 more than the araldite which you get a tiny amount in comparison I figured it wouldn't be as good.
    Anyway on with this sata data cable case update, it's a mix of 2mm alu as a 5mm strip with extra ears with mount holes in to attach to the mobo panel which goes from near the bottom of the 2nd level to just below the 8 holes I made for the pass trough's so it bolts on when all the cables are plugged into the mobo & 1mm alu & 1mm copper bent to make a nice cover to hide the horrors of the sata cables :D had to get my bending brake out for these though for the 5mm ends was too much for the weak ply wood & had to use the brake in a conventional & unconventional way to get all the right bends.
    Here's what it all looked like after thinking, designing, printing, sticking & cutting & before bending.
    All laid out waiting to be stuck.
    A kind of half arsed jig :D it was the middle piece that cut me, simple basic piece like that compared to all the other bits & that cuts me lol :D.
    Couple more shots of the pieces.
    And the extra copper details that I nearly put on the fans but scrapped the idea, they look kinda nice on this piece but undecided if I'll stick them on or not, if I do I'll cut some alu pieces to place on the copper bits too :) kinda looks like some kind of marzipan :lol:.
    By the time I finished placing the last couple of pieces with adhesive it had already started setting so had to remove the last 2 & clean off the partly dried adhesive & re stick them.
    Once things had set after 10 minutes I went all around the piece with a razor blade to take off any excess adhesive & took a few shots, it takes about 8 hours for it to fully cure.
    Up next for this is to very carefully brush it as 1 piece & then lacquer it :).
    Razer2007 likes this.
  5. robi09
    robi09 New Member
    20 Jun 2011
    Look very nice, how you bend the alumnium? :D
  6. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    Oh my oh my that is puuuurrdyyy! :clap: :clap: :clap: :clap:
  7. KidMod-Southpaw
    28 Sep 2010
    Sweet.
    Just plain awesome, love it!
  8. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    That's STUNNING - simply put.
    I'm SO glad you got that good camera - fap fap FAP!
  9. Nutman
    21 Oct 2008
    Oh, I like it better without those "eye"-things on top. Just the bent pieces side by side.
  10. Waynio
    Waynio Relaxing
    20 Aug 2009
    Thanks robi :).
    One of these, had it since my 2nd scratch build & it doesn't get used much but is there for when I need it & sometimes do :), I did try doing it with ply wood in a vice & was doable for 2 of the bends but the 5mm end ones needed something stronger so got my brake to work, had to use it the regular way & an irregular way because of the closeness of the opposing bends so for those bits I just used the break for keeping it clamped while I pushed it with a piece of ply wood :D.
    :D Cheers Razer :thumb:.
    Thanks KidMod :).
    :lol: Thanks Nutman :).
    That's 1 vote so far not for the extras :D, it'll make it easier & be done sooner anyway if I keep them plain ;) thanks for the feedback on that mate :).
  11. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    :jawdrop::jawdrop::jawdrop:
    that is just soooooooooooo beautiful.
  12. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    YEAH! I hoped you would do something about those:D And also knew it;)
    Taking it up, and up, and up, and up several levels at a time buddy!
  13. Korvus
    Korvus May contain traces of sanity.
    14 Apr 2011
    Yay :D More shinies :eek:
  14. Waynio
    Waynio Relaxing
    20 Aug 2009
    Thank you jokkos :).
    Cheers p0Pe :).
    :hehe: cheers mate :).
    To install hardware :rock::lol::clap::naughty::jawdrop::blush::dremel::D:eeek:.
  15. Razer2007
    18 Jul 2010
    woooohooo man!
  16. Waynio
    Waynio Relaxing
    20 Aug 2009
    :rock::D Cheers Razer :thumb:.
    Updated the mobo bios to the latest & got all other latest updates ready for a switch over yesterday, then got started at around 8 PM putting hardware in & getting the cable work done & installing win 7 & finally got it running, fully up to date & fully optimized & made a ghost image, took all night to do it all but I'm now typing from Stealthlow right now :D & woooooooo it's really nice & quiet & looks really good running, I took a good few photos of it during the night while I was putting all the hardware inside so I'll get them up in a mo ;), the noisiest part is the GPU, the RGB power cable though I'll need to get a new one, I was slimming it down so I could slip it underneath the hdd platform & I believe I cut an internal cable on it so need a new one so I haven't put the side panels on yet since it needs that last thing sorting but won't be able to get it until next Wednesday, other than that though it's all done & I can finally get stuck into a good game :thumb:.
    Still a night with lights & day photo shoot to do on this also :).
  17. Razer2007
    18 Jul 2010
    Now wheres the pics???!! come on, post 'em!
  18. ColdzeroTeam
    ColdzeroTeam New Member
    9 Dec 2010
    wow... that sata cable duct looks awesome :)
    congrats
  19. Waynio
    Waynio Relaxing
    20 Aug 2009
    :D
    Thanks mate, only problem now is I kind wish I made it so it covers them completely, I just did it so it goes to just below where they pass through, but it's good still :).
    Righty oh then :D.
    All done except for the RGB lighting which will have to wait, (knackered the power cable for it) but I can finally relax knowing that's the final bit, everything molex or fan related cables is nicely stashed underneath the hdd's :D so with the mass of wires going through the small mouse holes I had to make them bigger because of the switches for the lights on the fans so this pile of shots in bad lighting will be the last picture update until I get the RGB lighting sorted & then I'll put some effort into the photos at day & night, so I'm gonna get the weight back on & enjoy some good games until I can resume this, been feeling starved of some good gaming :D.
    32 photos so might have to do 2 posts in at least 2 forums I post at.
    Like this under both hdd cages :D.
    Old
    New
    In use finally :D.
    I love the unique light the fan holders project :).
    So, a little wait for the new RGB light power cable & then final shots, these are just to show it's now in use, mostly crappy shots I know but it's 99.9% complete now yaaaaaay I keep getting random big grins knowing it's in use now :hehe::D.
    When I walk into my room I can't even hear it & it's sat right next to my monitor so it's awesomely quiet, just the gpu that I can hear & that is with the side panels off :), :D time I got around to completing alice madness returns at last :D but I'll have to start from the begining again since I'm on a new os install on the super duper corsair force 3 120GB or the Yin Yang 120GB as I'll call it, here is a quick bench I did on the reads, veeeerrrrrry niiiiiiiice :D:rock:.
    Oh yeah the temps are better than air cube to my amazement, was expecting warmer temps but it out does the air cube by a few celcius which had much more air flow but this I really thought about the flow on how to make it work best & I'd call this my first perfect design :eeek::D:rock:.
    Forgot to weigh this beast so I'll weigh it when it's done ;).
  20. LeandroJVarini
    LeandroJVarini Mod is my life!
    25 Dec 2007
    magnific work! congratulations
