How are u planning on tidying up the backside? Wouldn't it have been a better idea to do that before u painted it? Nice looking big case, can't wait to see what u come up with
Yes it certainly would have been a better idea but I have a plan! I will try to use the mesh I was going to use to the fans, maybe I will cover the backside with lots of mesh.
Well , sorry for not updating this for weeks. I will wait with the case untill X-mas. I hopefully get a Dremmel for gift. Please keep an eye on this after X- mas. Edit: Ordered some switches,soldering iron ,volt meter and some "soldering-plates" today.
Your case is BIG but mines BIGGER!!! Looking forward to seeing this completed im sure its gonna be a killler
Was starting to wondering myself at one moment. Thanks for the comment. P.s: Har man inte stor nog får man ha nått annat stort istället
I got it! I got a Dremel with lots of tools. Haven´t tested it yet but sometime this week it will be.
I think the case would be much greater if you Cut your own front out of some alu with your new Dremel. Looking good so far. I got a Dremel to, but i only got like 5 cutting-discs with it so i had to go to clas-ohlson and buy some more... Btw: Vart bor du? Jag bor i Stenungsund, norr om GBG.
Case is looking good so far. Maybe you should etch out a design onto your plexi with that new dremel... Keep us posted!!! Again great work.
Thanks for the comments. I will not etch something to the plexi, to hold down the weight I will be using 2 mm plexi, it can be hard to etch in that. Now some pics: The plate is gone and the fan holes is bigger: My new modding mate: Model 285 BTW:Jag bor i Smedjebacken,Dalarna.
No , 13 "tools" + Bonus shield for sparks. 14 different sorts of discs. + 8 "tools" that came in the box with the Dremel.
Nice dirty grade cuts there True testiment to the spirit of modding in general. I'm actualy doing something simmilar to what you are, except a lil less powered (taking an old pentium laptop and [overkill] watercooling [/overkill] it into a large full tower like that). I am definately going to be following this mod! Nice dremel btw. What is that?^
I know,this wasen´t in my early plans but the inside got messed up so I repainted it in silver. I have also silver painted the mesh I´m using.
