Project: UnKnown
Discussion in 'Project Logs' started by moreDread, 31 Mar 2005.
  1. ^R3CoN
    ^R3CoN What's a Dremel?
    14 May 2004
    Nice case.
    I have a question, i haven't found the answer in your topic, but how many watt is your cpu tec ?
  2. DR_K13
    DR_K13 What's a Dremel?
    5 Jul 2004
    so nice!
  3. pc-modd.dk
    pc-modd.dk What's a Dremel?
    22 Apr 2005
    Nice work..
  4. moreDread
    moreDread What's a Dremel?
    24 Jan 2004
    The CPU-Tec is 226watts and the GPU is 80watts.
  5. moreDread
    24 Jan 2004
    Well i never thought it would happen but i got :jawdrop: "Mod of the Month" :jawdrop: in issue 27 of PCExtreme :clap:
  6. cool_dude
    cool_dude Minimodder
    26 Aug 2004
    this has given me the idea of doing this....hmmm :D
  7. BrokeEnthusiast
    BrokeEnthusiast What's a Dremel?
    28 Mar 2005
    I still love it, mainly because it looks kind of like my next case
  8. moreDread
    24 Jan 2004
    Well something i wasn't going to be doing for some time has come round a little quicker. And that would be fitting a Mach I prommi. But to do it i've had to hack up my old case so i can fit it all. One advantage is i can now move the pump and relay out of sight. The disadvantage is there is no way i will be able to pick the case up due to weight
    the old case as it was
    and after i've attacked it with a drill and jigsaw
    And attached to the prommi casing
  9. moreDread
    24 Jan 2004
    Well the prommi's fitted but not without its headaches. The main one being after fitting everything back in and pressing the start - nothing, not a peep, not even a fan movement. So i took out the mobo, everything looked fine, refitted and it fired up without a hitch. I guess its gremlins in the works :s
    A few pics for you to browse over are in order though....
    Mobo out the system and the neoprene cleaned off. A slight touch of moister was found but nothing that concerned me.
    The pics below just follow the installation of the AMD64 conversion kit for the nVentiv Mach I Prommi,
  10. moreDread
    24 Jan 2004
    The rest of these are of the case as it stands now... At some point i need to make a front cover the same as the main case plus rebolt the case to the prommi as its slightly off.
    Other things done though were the moving of the pump, re-routing the tubing to the gpu block and moving the relay. But now i need to sleeve more wires and general tidy of the case.
  11. arkadur
    arkadur What's a Dremel?
    3 May 2005
    :jawdrop:
    wow man!
    very nice staff! (and skills :thumb: )
  12. Jipa
    5 Feb 2004
    that's sick :D
  13. keir
    keir S p i t F i r e
    5 Oct 2003
    taking shape pretty well, well done so far. :thumb:
  14. mattthegamer463
    26 Nov 2004
    thats a good idea of putting the CPU piping in a cable sleeve so it looks better, nice job! :thumb:
  15. (spc)kuhnkejer
    (spc)kuhnkejer What's a Dremel?
    14 Feb 2005
    what neg 18 wasn't cutting it, haha. Anyways i love your mod, I have always wanted to put two cheap cases together. And for the guys talking about school, Ive learned more about about computers on my own then in collage. And most people dont know about tecs. Anyways i hate when people talk like they'er real smart because they know some thing grow up and let people learn from others. keep up the great work. ( do you want to sell any of the pelt stuff your not useing if so let me know).
  16. keir
    5 Oct 2003
    think thats standard :)
  17. dubya01
    dubya01 What's a Dremel?
    22 May 2004
    Hey wanna give your old a64 maze 4 to me :D
