Project: WET WEEKEND
Discussion in 'Project Logs' started by fatty, 19 May 2005.
  1. fatty
    fatty Minimodder
    12 Jul 2004
    Ok a while ago I stumbled across a stash of water chillers from drink machines and I thought to myself hmmmmm watercooling better yet very cold water cooling.....So I sold a few and kept a few
    Now I have been trying to find the best place to stick one of these units and I though I like the way a mach1/mach2 prometeia case fits under a pc very neat, so I purchased one and went about fitting it :)
    ( I haven't installed my ftp server apps yet so I will be a little while with more pics )
    will resize when I up load pics
  2. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    Nice idea :) should be very cool!
  3. Herbicide
    Herbicide Lurktacular
    27 May 2004
    Lay off the pun-ishment will you! This looks interesting though. Has anyone else used commercial cooling in a case before?
    - H.
  4. nick[x1]
    nick[x1] What's a Dremel?
    1 Nov 2004
    This is a great idea, make sure you post lots of pics :)
    If it works well i might be tempted to go back onto watercooling :eek:
  5. -Erik-
    -Erik- Guest
    Interesting is: How cold is the water now?
  6. fatty
    fatty Minimodder
    12 Jul 2004
    I had the chiller down to 2 degrees then it shuts off and back on again at 4 degrees C
    I do have a load of pics but I cant post in here because they are not on my website
  7. BrokeEnthusiast
    BrokeEnthusiast What's a Dremel?
    28 Mar 2005
    UPLOAD THEM!!!
  8. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    these compressors will work very mucht eh same as those in a freezer or fridge.
    which means they r not ment to run 24/7.
    ur freezer dosnt run 24/7, the compressor only turns on wen things start to heat up and reduces them back to ur set temprature. (easy enough as frozen food dosnt put out much heat :p)
    However a comp puts out constant heat so the compressor willbe working over time, i wouldnt be surprised to see it die rather quickly.
  9. BrokeEnthusiast
    28 Mar 2005
    When the compressor is turned off, there will not be waterflow, so how would it keep cooling?
  10. JavaDog
    JavaDog What's a Dremel?
    13 Mar 2004
    Refridgerators tend to be very well insulated. Notice that they usually kick on after the door has been opened...
    He is right about the compressors though, most are not made to be run non-stop. Often they will actually freeze up. Not too mention the condensation issues you will need to address...
  11. disco volante
    disco volante What's a Dremel?
    22 Sep 2002
    The compressor only affects the coolent. The water runs through a heat exchanger, and it's driven by the pump. The compressor not running has no effect on water flow.
    Here's my take on the duty-cycle problem. The bigger the resevoir, the better. Because, I think it would be easier for the compressor to cool down a big (insulated) tank of water, shut off, and let the water circulate. This would increase the actual amount of work the compressor has to do per cycle, but it would make the cycles much less frequent.
    Also, if you have two, you can alternate them for redundancy.
  12. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    like a watertank for a boiler (i think it's that) just to cool water down instead of heating it up
  13. fatty
    fatty Minimodder
    12 Jul 2004
    OK as for a refrigeration compressor it will run 24/7 no problems as long as the refrigerant isn't flooding back to the compressor disapating the oil etc and as long as the compressor runs at a suitable temperature
    Also it will have problems if it short cycles ie stops and starts too often and yes I am a HVAC engineer I do a lot of prometia work and people do run their proms 24/7
  14. fatty
    fatty Minimodder
    12 Jul 2004
    OK the mach1 case has been gutted and the chiller chopped up to see if it fits
    Then the brazing together
  15. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    when its finish lets see the water temp.
    where did you get that water cooler
  16. fatty
    fatty Minimodder
    12 Jul 2004
    Funny you should ask bit of testing on a simple loop
    polishing the case
  17. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    nice temps. remember insulation.
    btv. where is it possible to get those watercoolers
  18. vapb400
    vapb400 What's a Dremel?
    24 Feb 2005
    so what does each part do? I see the compressor, and heat exchanger, but what is the black box where the green tubing comes out of?
    Would you be able to run the loop without the compressor on? and only turn on the compressor when benching/gaming?
  19. c.u.later
    c.u.later What's a Dremel?
    16 Apr 2005
    hi fatty!
    i bought one of these units and so far its working great, i cant wait to see wot u do to yours, as your so good at things like this.
    @vapb4000 the "black box" is the actual part the water goes through which is wrapped in copper piping to cool it down.
    also, the compressor is the actual bit which keeps the refrigerant cooling the water, so i dont think thats possible as the water would heat up too quickly
  20. FliesLikeABrick
    FliesLikeABrick What's a Dremel?
    9 Aug 2004
    im not sure which black box you are talking about, but the big one is the resivoir, the small one is his waterblock
