Scratch Build – In Progress Project: X Marks the Spot
Discussion in 'Project Logs' started by TheGreatSatan, 14 Oct 2011.
  1. TheGreatSatan
    TheGreatSatan Member for 17 years!
    5 Aug 2005
    While I wait for all my parts to arrive for Bulldozer, I thought I would whip out a quick 2 week (or less) mod. I want to build a Treasure Chest PC for the store where I work in time for Halloween!
    I saw this cool looking chest on eBay and knew it was a winner. It's actually used for Wine bottles.
    I knew even from the auction photo that these would be perfect for 80mm fans
    And I was right...
    I want the computer parts to be separated from the "treasure" by plexi glass
    Like so
    Nothing says pirate like skull fan grills. Problem is that these are acrylic and doesn't exactly fit the weathered treasure look, so I painted them black
    And started putting them in with Red LED fans
  2. DeafGamer2015
    DeafGamer2015 Minimodder
    5 Jun 2010
    Jeesh TheGreatSatan,
    You really love modding alot huh? Let's see.. how many completed projects have you done??
  3. TheGreatSatan
    5 Aug 2005
    This is my 44th Mod
  4. TheGreatSatan
    5 Aug 2005
    I'm using a 300 watt Micro PSU, because it's all I have that even fits. I put this bracket in to hold it in place
    Here's it with the motherboard installed too. I'm using a socket 775 Pentium D 3.8GHz and an Asus board. The chip is only a single core, but at 3.8GHz it gets extremely HOT!
    The rear turned out well too
  5. lilgoth89
    lilgoth89 Captin Calliope
    12 Mar 2011
    if you wanted it to be cooler you could see if something like a mini ninja would fit on that cpu
    also dont forget to install some ventalation holes in the rear of the case to let the hot air escape
    ARRRRRGGG!!!!!
    heavy metal pirates ( alestorm ) comes to mind
    :rock: :rock: \m/ (-.-) \m/ :rock: :rock:
  6. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    About time you got started again! :lol:
    It's amazing how you keep spitting mods out!
    Not so much that you DO a lot of mods, more that every one of them are beautifull! :thumb:
  7. DeafGamer2015
    5 Jun 2010
    :jawdrop: 44?! holy you must have alot of money to do all these projects...
  8. JA12
    JA12 What's a Dremel?
    3 Mar 2010
    I think mr. satan is exchanging the souls of unbaptized children to computer gear :D
  9. TheGreatSatan
    5 Aug 2005
    I'm actually working on 3 right now.
    #42 - Bulldozer
    #43 - Studded
    #44 - X Marks the Spot
  10. DeafGamer2015
    5 Jun 2010
    Psh! I doubt it lol..
    At the same time? Whoa.. You must be very patient to do all 3 at the same time...
  11. Mosquito
    Mosquito Just 'Plane' Crazy
    24 Mar 2011
    Or very impatient and instead of waiting for parts, just starts a new project in the down time :D
  12. TheGreatSatan
    5 Aug 2005
    That too.
    I got the system booted up. I'm one intake fan short right now, but it is on order
    I'm using an old socket 775 single core Pentium with a 3.8GHz clock speed. I got this chip on ebay for $28
    Next comes my pot of Gold chocolate coins!
  13. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    chocolate coins are even more of a reason to keep it cool
    That would be a hard to explain if you tryed to RMA it :lol:
  14. Device Unknown
    Device Unknown What's a Dremel?
    13 Jul 2011
    Man, you beat me to the punch lol. I have some odd fascination for boxes. I collect them in all sizes, don't know why. So I always wanted to put a PC in one, just like yours. So make me proud bro, make me proud! ;)
  15. TheGreatSatan
    5 Aug 2005
    There will be glass separating the chocolate from the inyards. It will be sealed around the edges so if chocolate does melt it will not be able to get into the components
    Device Unknown likes this.
  16. kelvinb
    kelvinb BF3 Username - D0rmarth
    20 Sep 2011
    very nice mod cant wait for the next update ... would be cool if you could fit a TFT inside the lid and mod it to fit in with the theme
  17. TheGreatSatan
    5 Aug 2005
    My last fan arrived, so I put it in!
    Then my crappy Asus motherboard died. Even though it's 775, it's actually only 10 months old. Well, it does say Asus and they make nothing but garbage these days so it's expected. Instead, I added a jumper to the main power line so all the fans would just kick on without the Mobo
    Anyway, I added a some silicone around the glass edge
    And then I dropped in the Gold!!:clap:
  18. DeafGamer2015
    5 Jun 2010
    Do you have something to keep the coins cold so it doesn't melt all over the place? I know you sealed the computer section.
    And how are you supposed to get to the computer section if you sealed it already?! :eeek:
  19. TheGreatSatan
    5 Aug 2005
    There's 4 intake fans, the PSU has it's own exhaust and the motherboard/cpu aren't actually running....so I don't see a heat source to make them melt.
    By the time I'm done displaying it for Halloween, I'll just break the glass!
  20. DeafGamer2015
    5 Jun 2010
    Oh that's cool.. Just be careful.. Don't want to get glass in your hands or something.. :eeek:
    Also.. that's a awesome CPU right there.. 3.8 GHz? dang.. is that overclocked?!
