PSU PSU requirements for Dual GTX850 SLI
Discussion in 'Hardware' started by Hrodwulf666, 13 Sep 2012.
  1. Hrodwulf666
    Hrodwulf666 Arse about tit master!
    22 Sep 2010
    Hi all
    Have been searching for a definitive answer on this one, from what I can tell theres a LOT of split opinions on this.
    I have a 850w COrsair modular PSU and I want to run 2 GTX850's in SLI. My CPU IS overclocked...(specs in sig)... What you sayin?
    Cheers
  2. Maximilian
    Maximilian WC Virgin
    31 Dec 2008
    You'll be fine, I run the same setup from my Corsair 850, with overclocks etc... probably plenty of headroom too.
  3. Big Elf
    23 Apr 2009
    With an overclocked i7 970 and a pair of 580 GTX my power usage under typical rather than full load (3DMark11) is around 630W. If I put a decent overclock on the 580s then power usage rises to 940W. If I then overclock the 970 to it's max then it gets to just over 1000W.
  4. pullet_surprise
    pullet_surprise What's a Dremel?
    14 Sep 2009
    http://extreme.outervision.com/psucalculatorlite.jsp
  5. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    I assume you have measured with a wall meter? Did you consider PSU efficiency in these numbers?
    That calculator overestimates by a good amount.
  6. rollo
    rollo Modder
    16 May 2008
    My old i7 950 and 580 sli setup drew 800 watts under furmark ( CPU at 4ghz) 680 sli same CPU is below 500 watts. These are all measured from the wall.
  7. Hrodwulf666
    22 Sep 2010
    So???? Am I ok???
  8. David
    7 Apr 2009
    Are you keeping the 460 as a physx card?
    If so, I think you're pushing the limit.
    Without the 460, it should be ok as long as you don't plan to overclock the cards.
    jizwizard likes this.
  9. Hrodwulf666
    22 Sep 2010
    No I will be getting rid of that. There's not enough room for it as well.
    I don't think ill have to OC the cards. This is the last upgrade I plan on for this PC.
  10. rollo
    rollo Modder
    16 May 2008
    If your Overclocking the 580s no chance 850 is enough as I've seen 1000 load under furmark when pushing those cards.
    CPU keep it below 4.4ghz and you will be fine.
  11. mm vr
    18 Nov 2007
    Corsair PSUs should be pretty robust, and they have proper overload protection as well. You could try with your current unit, and if it starts powering off intermittently, you'll know what the problem is. You could even grab a wall meter for £5 and check the real power consumption.
  12. jimmyhelu
    jimmyhelu What's a Dremel?
    25 Aug 2012
    I'm having a hard hard time here, I tryed swaping each out and different x16 slots, different power options.. I'm not sure what I have left to do.. Just thought: I DID buy these cards from walmart.com and they are EVGA 03G-P3-1584-TR
    which is not on the product list on the graphics card page
    I used Passmark software benchmarking too.. over and over it gets low ratings in the 15-17 FPS..
    on a card I used to have (MSI radeon 6950) i hit at least 90 on the same test (it only runs on a 1024x720x32 resolution too..)
