Quake Machine
Discussion in 'Project Logs' started by Gizmo, 21 May 2004.
Continue with modding even if it is a AT
  1. Yes. Continue
    80 vote(s)
    61.5%
  2. No. Start with another mod that is an ATX
    50 vote(s)
    38.5%
  1. Gizmo
    Gizmo What's a Dremel?
    21 May 2004
    Owkee. Tommorow 24/05/2004 I have to go to school and I am back at 4:45PM :waah: . I will try to cut it out in the evenig. I will update this on 24/05/2004 in the evening. See ya
  2. Gizmo
    21 May 2004
    Owkee. So far so good. I cutted 2 pieces. I din't had more time to do the rest. Tommorow I will send up more pic's. Keep on modding ya'll :thumb:
  3. Gizmo
    21 May 2004
    Owkee. RED is cutted out. (not bad for the firste time with dremel I think :dremel: ). Now I have to wait to vryday to get paint. The only thing I can do is making the case ready to paint. Well that's all.
    Please send me if you have any Idea's :idea:
  4. Gizmo
    21 May 2004
    Used 4 dremel cutting disc's for the red circled place's. Is that normal?
  5. agent orange
    agent orange What's a Dremel?
    8 Dec 2002
    read this: Dremel Techniques that should help a bit.
  6. Gizmo
    21 May 2004
    Thanks mate :thumb:
  7. Acid Burn
    Acid Burn ..look but don't touch..
    14 Mar 2004
    Looking great there pal! :D
    :dremel: Keep moddin' :dremel:
  8. Gizmo
    21 May 2004
    Gone for a while
    Owkee guy's, I have been gone for a while (to long if you ask me :rolleyes: ). But I am back and I got some paint today.
    These are the spraycans. I think that I will use the three red cans on the left. The middle one is a od paint but I think I will use it.
    This is a closeup of the type of paint that will come out of the middle spraycan. ;)
    I will keep you up to date :thumb:
  9. Acid Burn
    14 Mar 2004
    hehe thread revival :p still looking good mate :) just for the record... you will need a lot more paint than that :)
  10. Gizmo
    21 May 2004
    I will use the paint and see how much paint i need, i bought it for 2 $ for one spraycan so that is not much isn't it :hehe:
  11. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? What's a Dremel?
    13 Jun 2004
    ya that middle spray can you got going, it does not look all the great but the texture that it leaves is one of a kind, i got a can at home, it feels so cool!!!!
  12. Gizmo
    21 May 2004
    DAM THAT FU@!I^G SCHOOL. I DIN"T DO S@!T TODAY. Well lets see if i can do work tomorow sorry about the hard word's :lol:
  13. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    Cool mod mate. Very clean and nice.
  14. Gizmo
    21 May 2004
    Are you serious or are you kidding. It's my very first one and the first time i work with dremels and stuf.
  15. -N4cR-Stigma2K
    -N4cR-Stigma2K Banned
    8 Jul 2004
    Simply love this case
    Isn't it a case from the jolly old Pentium 1 days?
  16. Gizmo
    21 May 2004
    Yes, I don't use it for years and I thought it was a sheame to use a new case for my very first mod ( if you get wat I mean ;) ). So I am trying to see how its like to mod and that sort of things.
  17. apHytHiaTe
    apHytHiaTe What's a Dremel?
    9 Jul 2004
    nice cutting
    :hehe: hehe thats pretty darned funny man. really it is gonna be sweet, and i think its cool of you to do that for your dad! have some confidence ;) cuz i'd let you cut on a Lian Li... if i had one!
    ps. like the paint! the fleck stuff. I just got some metalcast, which i have no use for YET, so im wondering how your fleck works out :)
  18. Gizmo
    21 May 2004
    Tnx m8
  19. Gizmo
    21 May 2004
    Messing around
    I was boring around on the net and I saw how you can make bulletholes in plexi ( CD case). So I thought "Let me have a try". So I jumped in my "workshop" and grabbed my dad's dremel :dremel: (witch I am the only one who ever used it ;) ) and a jewelcase from CD case and a drill. And this is how it worked out. Not bad for the first time try to make a bullethole.
    For those who want to know how I did it here is how I did it.
    * I drilled a holle with a 9mm drill *
    * Grabbed the dremel and going with the cutting disc slaitly over the eges of where I drilled the hole to make it more white (on both sides of the jewelcase) *
    * Then going slaitly from the hol going away from the hole, to make the (deep cracks). (Only on 1 side of the jewelcase) *
    * When you have the (deep cracks) the make (light cracks) from the (deep cracks). (on the same side of jewelcase as you did the deep cracks.
    And you will see that one side is better then the other. It is the side where you only used the dremel to make the bullethole more whiter and not the side where you maked the cracks
    And if you not really onderstand just ask for a better explanetion or just try it and you know that it wil do almost itself. :thumb:
  20. TheSchumi
    TheSchumi What's a Dremel?
    13 Aug 2004
    Mhhh... Dremel suckz for such work. I use a classical leaves saw for such work.
