Radiator to radiator in loop?
Discussion in 'Watercooling' started by Hitman, 1 May 2018.
  1. Hitman
    Hitman Minimodder
    18 Oct 2002
    I have two 240mm radiators which I was thinking of running in the following order:
    Pump/res > GPU > CPU > 240mm Coolstream SE > 240mm Coolstream XE > back to pump/res.
    Any issues/thoughts on running them in line like this? Trying to workout a nice clean layout for a loop in a Meshify C and this order make it a bit easier to run the pipes, as the block on the GPU exits out of the rear rather than the side.
  2. The_Crapman
    5 Dec 2011
    That will be fine, the order of the loop doesn't matter and having thembin that order won't affect the temps at all.
  3. cobalt6700
    cobalt6700 Minimodder
    17 Oct 2005
    As Crapman said - order of the loop doesn’t really matter. So doing it the least restrictive/best looking way is the best way to plumb it. Only order that does matter is res -> pump :thumb:
  4. Hitman
    Hitman Minimodder
    18 Oct 2002
    Nice, I've read as much but never done rad > rad before. That makes thing easier! :grin:
  5. cobalt6700
    17 Oct 2005
    Just think of it as one big rad - not much difference physically :)
    Hitman likes this.
