Raid array can't work with Alcohol?!?
Discussion in 'Hardware' started by Otto's, 5 Nov 2006.
  1. Otto's
    Otto's What's a Dremel?
    16 Jan 2004
    Hi everyone !!.. recently I got a nforce 5 motherboard running Raid 0 with two
    300GB SATA Harddrives . Both HD are connected onto the MCP ( Southbridge ).
    The array work perfectly fine . But the problem is , I can't install some of my games using Alcohol or Daemon tools . I tried to install games onto another non-raid HD and it's works.
    Do anyone one of you have any ideas? could I solve the problem?
    or it's a fact that virtual disc programs can't work with raid ? :sigh:
    Thanks!!!
  2. specofdust
    specofdust Banned
    26 Feb 2005
    There should be no reason a CD mounter couldn't install a RAID array. Windows just thinks RAID arrays are big large disks. Dunno what's up to be honest.
  3. Otto's
    16 Jan 2004
    I re-create the array using settings of : stripping Block : 32K
    Boot : Yes
    now it seems to work fine.
  4. overdosedelusion
    overdosedelusion I mostly come at night, mostly..
    29 Oct 2006
    when i read the title i figured you were pissed and trying to set up RAID
  5. customh
    customh conflagration.
    22 Oct 2005
    lol, even this being only the second post i have seen from you overdose I can see how you'd take it that way.
  6. Superlunchbox
    Superlunchbox What's a Dremel?
    13 Jan 2004
    LMFAO! I thought the same thing. I use alcohol exclusively when I can't figure things out in life! :)
