Reviews Raijintek Scylla Elite 240mm Watercooling Review
Discussion in 'Article Discussion' started by bit-tech, 30 Sep 2021.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Paradigm Shifter
    10 May 2006
    I'll be honest, while several of the criticism levelled at this kit are valid, I find the "con" of "Rads that haven’t been flushed" to be a bit... well, I'm torn between obvious and nit-picking. I've bought radiators from a variety of different manufacturers, and all of them have had something come out when I flushed them. Some worse than others (a "no name" Chinese radiator which came in a box with the only identifiable marks were the ideograms for "water" and "river" was the worst offender) but they've all needed a good rinse out prior to use.
    enbydee likes this.
  3. The_Crapman
    5 Dec 2011
    There's a big difference between "having a few little bits come out" to "holy cow these rads haven't been flushed at all.", which is what I got in this kit. I have never seen anything anywhere near that bad in rads I've used from alphacool, ek, thermaltake, xspc, Corsair, hw labs. That is not nitpicking, in my opinion.
    I also try and test hardware with a viewpoint of a first timer because they will need help and advice more than a seasoned pro. Kits especially are aimed at first timers who want the comfort of knowing they're getting everything they need in one box, which in the case of this kit, they do not.
    Paradigm Shifter likes this.
Tags: Add Tags
