Scratch Build – In Progress Rasberry Pi Competition: epA eparG
Discussion in 'Project Logs' started by Cheapskate, 20 Feb 2013.
  1. Cheapskate
    13 May 2007
    What?
    ...anyway. I've had an idea for what to do with my bountiful scrapheap for some time now. BitTech has supplied a perfect reason to play with the concept.
    -Also I've had the saw set up in the winter jungle for tile work. It was like the planets lined up or something...
    -First, I take some scraps and cut them into little strips. I'm sticking with a glassgreen/blue/purple/and some red color scheme.
    -Glue strips into bigger strips...
    -Strips into plates... Do you see a theme yet?
    -I had to cheat and mill the edges clean so I can make a box-thing.
    -I added some sides plates. Here you can see my high-tech R PI stand-in made from an old sticky note.
    -Here I've started putting together the other sides.
    -Did I mention I'm getting help from yet another new toy. Someone cornered me into a crazy project that required it, It'll be useful here too.
    -I had a butt of a time getting some red into the picture. I'll add some to the inside later to balance out.
    -I've stepped up to a super-high tech version of my Pi stand-in.
    -Next up is more milling. I'm posting today 'cause the saw was borrowed again.:( I may have to get creative with the last bits.
    :)lol: limestone dust everywhere. what a slob.)
  2. Waynio
    Waynio Relaxing
    20 Aug 2009
    Grape Ape :D nice use of scraps. :)
  3. tekonivel
    tekonivel Minimodder
    14 Jul 2012
    Good to see you decided to jump in the comp. Looking good.
    Good luck for the competition.
  4. Asouter
    Asouter --------
    18 Jan 2012
    Looking forward to seeing how that machines, with the strips of colour it should look pretty cool
  5. Cheapskate
    13 May 2007
    Thanks.:D
    @Waynio - Thanks for saving me from page 2.:lol:
    @tekonivel - I can't pass up a contest like this. I fear The Wet Pi was posted too soon. We may lose a lot of contestants because they know we will all lose.
    @Asouter - It does well, 'cept for the white strips. They have a lot lower melting point than the other stuff.
  6. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Cheapskate, where is the update?
    I am following this log and can't wait to see more.
  7. Combatus
    16 Feb 2009
    NiiiiiiiiiiiiiiiiCE! :D Glad we could give you the excuse to mod, even if it's the smallest project you've worked on cheaps! Will be following this one!
  8. Cheapskate
    13 May 2007
    Aw, shucks. Now I have to work faster.:lol: Thanks, guys.
  9. craig - toyoracer
    craig - toyoracer Minimodder
    1 Mar 2011
    Those rainbow panels are a nice start Cheaps. :)
    Looking forward to this quick build. :lol:
  10. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    This is Cheaps we're talking about here - he'll still be working on this mod loooooooong after the competition has finished :D :lol:
    Cheapskate, when you say you want to get more red into the design, bear in mind that the Pi's main power light is a reasonably bright red LED (I think).
  11. Cheapskate
    13 May 2007
    Ah, There's the red, then.:lol: I didn't think they had a power indicator on it.
    I will try to finish on time. Just yesterday I was milling a bunch of elaborate pockets in the top, only to find I'd spent most of the time cutting air.
  12. Cheapskate
    13 May 2007
    My fixture technique will be sandwiching the PCB edges between the lid and the base in a neatly milled pocket. -Of course, I don't have a PI to prove it works...
    -I sanded the top, (bottom?) down to an inch in height, then clamped her in the mill.
    -Then I milled everything down clean and even.
    -Then I spent a small eternity milling a dozen pockets in the main cavity. 90 Percent of that time the bit was waving around in open space.
    -I used my printed model to figure out where I could put screw holes. I only need two. It's not like this thing needs to be shot out of a cannon or anything...
    -I didn't need to drag the drill press out for it either. It's much easier to sit on the floor like a ten year old and drill. You will note that I still managed to keep my feet out of the shot.
    This is what happens when you use a power sander on extruded plexi. I keep forgetting the white stock I have was cheap because it was 'struded. Little moments like this remind me.
    -I clamped it all together and gave it a quick and dirty polish.
    Next up, I need to drill and file out the ports.
  13. Father-Time
    Father-Time Minimodder
    23 Feb 2004
    Looks good cheap :)
    Gotta love the drill that tells you which setting to use for which screw ;)
    The colouring of the plexi/acrylic has come out really well, its a good blend, i like it :)
  14. Phame
    Phame COOOOFFFFEEEEE
    17 Sep 2012
    Sexeh! Looking good Cheaps! :D
  15. Cheapskate
    13 May 2007
    Thanks.:D
    @Father- I'd much rather have the trigger from my older drills. They had fantastic speed control.
    -I might try to re-fit them with modern batteries some day.
  16. Asouter
    Asouter --------
    18 Jan 2012
    All those levels of colour look really good, I wonder if there's some process where you could melt all those layers together so that they swirl (psychedelic looking) like an old 70's album cover ?
    looking good though Cheeps :D
  17. Ragequit
    Ragequit What's a Dremel?
    26 Apr 2012
    Looks good! Love the humor you put into your updates, and well, everything you say everywhere. You make this forum a happier place!
  18. AverageNinja
    AverageNinja Almost an EpicNinja
    6 Aug 2012
    Nice one cheaps! Can't wait for MOAR!
  19. tekonivel
    14 Jul 2012
    Good work Cheaps!
  20. Cheapskate
    13 May 2007
    Thanks, guys:D
    @Asouter - Plexi bubbles up when it gets close to the melting point. It stinks like mad at that point, so someone else will have to hot cast it.
    @Ragequit - Humor?:eyebrow:
