Hardware Raspberry Pi review
Discussion in 'Article Discussion' started by brumgrunt, 16 Apr 2012.
  1. schmidtbag
    schmidtbag What's a Dremel?
    30 Jul 2010
    It is, but I wouldn't say its fair to call the OS in general immature strictly because of drivers. And as I've said before, debian squeeze is extremely out of date, there have been immense performance improvements to ARM that squeeze doesn't offer. Note that in the linux world, 6 months is like 3 people-years.
    Fair enough, although I don't remember you specifying that you used one of these remixes. Keep in mind that many changes that occur in derivatives of distros don't always make it back to the parent distro, so it is completely possible that the Pi remix is notably faster than the default. Again, remix or not, squeeze is not going to give you desirable results. You just said "latest release" which could mean latest stable, unstable, or testing. I'm not trying to be an ass or anything, I'm trying to be informative. You'd be surprised how big of a difference there is between each repo of debian.
    I actually completely forgot that you mentioned Quake III, my bad.
  2. Gareth Halfacree
    4 Dec 2007
    It's impossible to get a vanilla build of Debian (or any other operating system) to boot on the Raspberry Pi. You need to either do some serious hacking, or use one of the spins available from the Raspberry Pi download page, where someone has done the hacking for you.
    Re-reading the review, I wasn't clear enough in what I was saying: where I'm talking about the 'default Debian distribution,' I don't mean vanilla Debian - I mean the default distribution provided on the Foundation's download page, specifically for use on the Raspberry Pi.
    I'll go and amend that bit, save other people's confusion - ta!
    Given that I do distro reviews for Linux User & Developer Magazine, I don't think I would be surprised. ;)
  3. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    I'm interested in one as bit-torrent box, would I be able to use a USB hard drive alongside one, or is that asking too much?
  4. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Not sure it has enough power to support an emulator & game.
    That said, try Oolite - a freeware Mac Os / Windows / Linux port of Elite. You'd need to compile it from source though.
  5. Gareth Halfacree
    4 Dec 2007
    That'd work fine. There's actually a trick to getting host bus powered devices working: plug a powered USB hub into the mains, connect it to the RasPi's USB port, wire in your bus-powered device and then connect a lead from the hub to the Pi's microUSB power socket. The result: everything draws its power from the hub, and you only need one mains socket for the whole lot.
  6. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    Must... Water Cool... It... :D
  7. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    It might also be worth trying Arch Linux as that is typically on the bleeding edge - kernel 3.3 is already in the official repo. You could also squeeze a lot of performance out by compiling packages yourself (possibly using DistCC to do the heavy lifting on the main computer) and setting mtune parameters for the RPi. Ditto for the GPU driver.
  8. ADJB
    ADJB What's a Dremel?
    7 Apr 2010
    A port of the FUSE Spectrum emulator is already up and running so given that there isn't a massive difference between a Speccy and a Beeb (or any of the other classic 8 bits) in terms of memory, overall power or game complexity then once the relevant emulators are ported I would be very surprised of the power of the Pi was an issue.
  9. Madness_3d
    Madness_3d Bit-Tech/Asus OC Winner
    26 Apr 2009
    Kinda glad I didn't get one now, will wait for a Raspberry Pi 2 and hope the whole platform is a bit more mature :)
  10. lp rob1
    lp rob1 Modder
    14 Jun 2010
    Shame about the lack of Gigabit Ethernet. Would make the perfect file server if it had. Hopefully the Pi Foundation (read: Pie Base) will notice our comments and reflect with the Raspberry Pi 2.
  11. blackadda15
    blackadda15 What's a Dremel?
    28 Apr 2010
    Just got mine through the door let the experiments begin.
  12. Neogumbercules
    Neogumbercules What's a Dremel?
    14 Aug 2004
    All I need to know is if there's a SNES emulator out there that will run on this thing.
  13. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    can i play angry birds on it?
  14. tonyd223
    tonyd223 king of nothing
    12 Nov 2009
    OK, I'm old enough that I remember having a ZX81, I see the point of learning to program, but I'm just not sure of the relevance of this... I'll watch this space with interest, and it's so cheap I'd probably buy one anyway, but what would I use it for? I look forward to a dedicated projects page for inspiration
  15. Fordy
    Fordy Minimodder
    28 Feb 2010
    Yes. I'm a lower sixth student, pre-ordered one on release day.
  16. Fordy
    Fordy Minimodder
    28 Feb 2010
    Now where's the fun in that? :p
  17. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    Definitely want to pick one of these up. For the price there's just no reason not to, even if it's not some miracle machine. Thinking it would go well in a simple enclosure mounted to the side of an external USB hard drive. Hard drive plugs into one of the Pi's USB ports, a wireless KB+M plugs into the second, and assuming you can get decent video playback setup you've got a niftly little portable HTPC.
    And more seriously, who's to say there'll be a Raspberry Pi 2?
    It's a learning device first a foremost, and a modder's playground second. For the former not a lot of power or features are needed and most educational institutions aren't going to be looking for a new device now that they've already got one that meets their needs so developments of a Raspberry Pi 2 isn't exactly necessary. For the latter you're dealing with people who enjoy tinkering and making things work, the future of the device will depend largely on their work and creations as its limits and areas needing improvement are discovered.
    TL;DR, if you want a Raspberry Pi 2 the best thing you can do is pick one of the first models up and have a go with it. It's cheap and you'll be supporting the creators.
  18. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    Given that you can buy a NAS with a built in bit-torrent client for less than the cost of a Pi, which will work out of the box and look a lot neater, there isn't much of a need to IMO.
    Not saying it wouldn't be cool though!
    edit: first post in 11 months. Pi is awesome enough to have brought me back, despite the issues that made me leave :)
  19. dark_avenger
    dark_avenger Minimodder
    9 Jul 2008
    A NAS with bit torrent for less than $35? Seems unlikely....
    Already pre ordered one to play around with. Mostly to play with the XBMC port but also looking into whole house audio using a few of them.
  20. fluxtatic
    fluxtatic What's a Dremel?
    25 Aug 2010
    Didn't I already see someone here working on that?
Tags: Add Tags
