Scratch Build – In Progress RasPi - XBMC - FINISHED
Discussion in 'Project Logs' started by Canardwc, 7 Nov 2012.
  1. Canardwc
    Canardwc @French_fab_factorie
    22 Sep 2011
    New Raspberry Pi for Media Center based on XBMC.
    The problems of the Raspberry are:
    N°1 - Need to had a powered USB HUB for more USB devices.
    N°2 - If you need a powered USB HUB, you need an DC/AC plug and RaspPi need another ONE. Finaly, you need TWO???? :eyebrow: 2 for 1 small computer??? Too Bad!!!
    N°3 - have you ever see a RasPi? Have a look bellow. There are plug everywhere on all sides. (how do a nice little case look in those conditions?
    N°4 - Need a case that doesn't exist... A problem? Not really. MMMMOOOODDDDDDD :dremel:
  2. Canardwc
    22 Sep 2011
    Project:
  3. Canardwc
    22 Sep 2011
    Presentations
    1 - Presentations
    The RasPi
    The HUB
    Both
  4. Canardwc
    22 Sep 2011
    First PROBLEM
  5. Canardwc
    22 Sep 2011
    So I decide to keep only one power plug for both "cards". I decide to keep the USB HUB power and condamn one port of the HUB to use it as RasPi POWER.
    RasPi POWER plug (an old Noki@ charger)
    Connected to the condamned USB port of the HUB.
    Connecting the Hub to the RasPi
    HUB connected to the RasPi
    Power plug must be moved to the rear of the case
  6. Canardwc
    22 Sep 2011
    Removing the RCA video outpout (because of the HDMI and it's on the bottom of RasPi) and prepare the mounting plate to associate RasPi and the HUB
    Glued Aluminium HUB/POWER plate on the ethernet device
  7. Canardwc
    22 Sep 2011
    Glue is dry...
    Power HUB moved
    2nd step, glue the hub to the plate
  8. Canardwc
    22 Sep 2011
    Then... My discusting work is working..!
    Waynio likes this.
  9. Waynio
    Waynio Relaxing
    20 Aug 2009
    I like it Canard & love the additional USB ports :thumb: will be awesomely small & neat. :D
  10. Canardwc
    22 Sep 2011
    I try to keep the interest of the RasPi.. Thks
    And Thks Again, from you, I take it as a compliment. :D
    I haven't the choise with the posh glue work, there are no holes on the 2 cards... no holes = no screws... :grr:
    But you do an awsome job on your Scratch' Builds! And quite neat :D
  11. jinq-sea
    15 Oct 2012
    I like this a lot. It's a nice change from the high-power systems. Keep us updated!
  12. jay2
    jay2 Indonesian Modder
    3 Oct 2012
    I'm still waiting my raspi delivery :(
    an XBMC+android raspi would be great..
  13. Canardwc
    22 Sep 2011
    XBMC is the best OS for RasPi i've tested yet. Light and quite reactive for this little SOC with 256mb of shared ram. Really acceptable for video and music. And the sound is really good.be patient.:lol:
  14. C4B12
    C4B12 Minimalistic PC's
    6 Oct 2011
    Hmm this gives me ideas! :D
  15. jrs77
    jrs77 Modder
    17 Feb 2006
    Nice idea to build something really small.
    What I don't understand tho, as you allready started to solder/desolder some parts... Why didn't you just desolder the power-plug of the RasPI or USB-Hub and make a permanent wired connection between the two boards? Same for the USB-ports ofc. Would've been even better imho and it would look neater aswell.
  16. Canardwc
    22 Sep 2011
    Sizing question; have you ever weld micro usb on printed circuit? TOO SMALL!!!
    But if I could, I'll do.
  17. Canardwc
    22 Sep 2011
    A RasPi in aluminim coc@ col@ bottle?? :naughty:
  18. jrs77
    jrs77 Modder
    17 Feb 2006
    Ah OK. Thought you'd have some equipment to solder SMD-components ;)
  19. Canardwc
    22 Sep 2011
    Unfortunatly, don't have those kind of equipments... :waah:
    I do with stuff on board
  20. Canardwc
    22 Sep 2011
