Case Mod - In Progress ReactorMod rusty project. FINISHED - final pics!
Discussion in 'Project Logs' started by Piotrek_PL, 30 Mar 2013.
  1. Piotrek_PL
    Piotrek_PL What's a Dremel?
    29 Mar 2013
    Hi there! It’s my first post here so I thought it would be nice to write a few words about myself before I proceed to the project log. I’m not a native English – I live in Warsaw in Poland – but I will do my best to use proper English :) I’ve completed several small mods that are not even worth posting here but I think I’ve learnt a lot while building them. Oh how much metal sheets I have trashed before I’ve caught how to do stuff.
    Now thanks to my older brother who’s set up a small workshop in the basement I have a chance to make something better.
    Ok but lets get back to the project. I’ve stared it in July 2012 and I kept a log only on my local forum. Now the build is quite close to an end so I decided to share it with you.
    I was thinking about a way to write this log for a while and because there’s a lot of stuff to show I’ve decided that the best way would be to divide it by particular parts of the case. I don’t want to spoil the fun and end this log too quickly :) And I must admit that writing this log takes more time than I expected.
    Hardware. It's not really anything to be proud of, just my computer for every day usage.
    CPU: Athlon II x4 640
    MB: MSI 870-C45
    RAM: 2x2GB Kingston HyperX
    GPU: GeForce GTS450 512GDDR5
    HDD: 120GB Kingston SSDNow oraz 250GB Seagate
    PSU: Chieftec 450W
    I’m proud to say that all water cooling parts used in this build were sponsored by EK Water Blocks.
    I want to make a case that will look like old, a little seedy like it was used for many years in bad conditions, in a factory or something. You know – rust, cracks and so on. I was inspired by some old control and measurement instruments and stuff that I’ve found on the nearest scrap yard :)
    I’ve started looking for some case in the online shops and I decided to buy second hand Chieftec BX-03. It was cheap and looked like easy to mod.
    I’ve started from modding the front panel. Striped parts removed and mesh put instead. Luckily everything was mounted only with some latches so there was no need to cut.
    Then I cut the mesh and bent it. It’s all screwed with nice rusty screws that I kept for a special occasion.
    Overall view of the front panel.
    The right side of the case also needed some change. There were two air-holes, I decided to get rid of them and put some mesh instead.
    Again: cutting and bending and finally it's a perfect fit.
    In this photo you can see the screws but then I decided to use pop-rivets, but the mesh must rust before riveting it.
    I left all the mesh outside on the rain to rust and started work on the left side panel. There will be a lot to do with it :)
    More to come soon...
    and sorry for my bad English :)
  2. Piotrek_PL
    29 Mar 2013
    Sponsored by EKWB
    Afterwards I began the work on the left side panel of the case. I remembered having old switch that I've found on the scrap yard.
    The switch is mounted, it was a quick job, only three holes were needed. I've decided to make a series connection between those black buttons so they will work as reset switch only when pressed together. The red button will be power switch of course.
    And a quick look on the insides :)
    Now it was the high time for bigger changes in this case. After some quick welding the radiator mount is made. Photo was made before drilling holes for screws.
    The radiator is mounted.
    As you can see in the photo above the radiator is sticking out a mile from the case, so I had to cut the left side panel.
    A day ago I saw a perforated metal sheet and I couldn't resist to buy it. It turned out a great solution for building the radiator cover.
    Cutting...
    ..bending...
    Finally I made a nice box
    and welded it onto the side panel. In this snapshot you can also see the lines for cutting the window.
    It was quite dark already but it didn't put mi off. I prefer to use grinder outside because my workshop is very small :(
    Once I cut it I could get back to the basement :)
    How do you call this kind of gasket?
    The window will be made from parts of an old laptop broken screen.
    Hope I didn't overdo with this cracks.
    Let me know if you like it, expect the next update in next few days :)
  3. Parge
    16 Jul 2010
    Love it, and really enjoy seeing old cases made good again!
  4. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    Nice industrial look. I like the idea of making those old workshop style switches as power buttons. Are you going to do anything about the rusted parts? You don't want the rust to spread all over the rest of your project.
    It's nice to see a project that isn't just made by throwing money at it.
  5. Sheiken
    Sheiken Wat?
    9 Jan 2005
    Loving it!
  6. matiss
    matiss Minimodder
    24 Jun 2010
    Instantly reminds me of Stalker and Metro 2033. Very nice.
  7. Piotrek_PL
    29 Mar 2013
    thanks. I'm not going to do anything about the rusted parts, actually I do want this mod to be rusted and later I'll be adding even more rust :)
  8. Piotrek_PL
    29 Mar 2013
    Sponsored by EK Water Blocks:
    OK guys that's gonna be a bigger update! This time I'll show you the building process of the reservoir.
    The mesh that I put into the side and front panel rusted nicely.
    Let's get around to the res.
    Started with aluminium pipe (60mm diameter)
    A while of milling. In this photo there are three separate 'bean' shapes cut but then I thought that a one longer will look better.
    Now it's time for the res window. First time I've made it from epoxy resin
    it went out pretty good
    but sadly there was a small leak between the window and the pipe (don't know how that's possible, I think it's because of different thermal expansion of the epoxy and the pipe), so I came up with a new idea. Drilled and rifled 8 holes that will hold a plexiglass. It's now sealed with silicon. No more problems :)
    Then I proceeded to the 70 diameter 20 mm thick aluminium rod slices.
    After a while of turning they changed a bit. They will be the reservoir caps.
    This one will be the bottom one. Two G1/4" threads.
    And this will be to upper one.
    The plug for connecting the UV diodes that will sit inside the res and the plug for filling the reservoir.
    That plug needed some turning to allow it to screw in completely.
    Once the res itself is made it's time to make it's mount. It wasn't hard, just a 2 flat bars with 4 holes in them and a 2 rifled 5mm diameter aluminium bar.
    I also made a pass inside the case for the hose.
    And the final look on the front.
    Hope you enjoyed, sorry for the mistakes and stay tuned! Next update soon :)
    Livio likes this.
  9. dreps
    dreps Minimodder
    3 Oct 2012
    looking stunning already :D keep up the nice work!
  10. ziza
    ziza What's a Dremel?
    21 Dec 2010
    Hehe this is a tough project.
    Nice res.
  11. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    alu + cu (WB and rads - bad idea due to galvanic corrosion
    Pranja likes this.
  12. Piotrek_PL
    29 Mar 2013
    yeah I know about that, that is why I've covered all res on the inside with the layer of epoxy and I will be using the EK Coolant which contains a corrosion inhibitors :)
  13. Pranja
    Pranja Blackwolf
    18 Dec 2011
    +1
    Really not good idea. If you want Alu,whole loop must have Alu components.
  14. Piotrek_PL
    29 Mar 2013
    Yeah guys I do know about it, that's why I've covered all the reservoir on the inside with a solid layer of the epoxy. And I will be using EK- Ekoolant which protect the loop from corrosion. Anyway I realise that I'll have to be careful with that :)
    edit. sorry for double post its because I was using my smartphone..
  15. Piotrek_PL
    29 Mar 2013
    "The amount of posts in this thread
    Is too damn low! :)"​
    I expect this case to be quite heavy, so I added four eye nuts as some kind of hooks.
    Fitting before welding them in place.
    Drilled 4 holes for the screws and welded.
    There's really not much to say about that, see the outcome. Later I will remove the zinc coat from the nuts to make them look old.
    Close-up.
    Overall view.
    I like how it went out :)
    In this build I will have several things which voltage I'd need to control (fans, light, pump and so on) and I don't want to use ordinary control panel so I decided to build one from scratch.
    After a while of wondering this is what I made.
    I think it's the simplest circuit possible based on the LM317t. As gauge I will use 12V bulb per channel running on 6V when max output volatge is set, so they won't dazzle eyes.
    After bending this is gonna be the controller case. 2mm thick steel.
    Good hammer comes in handy!
    I had left some perforated steel so I used it on the sides. That's finished controller case.
    First run of the controller. Dat feeling...when everything works fine on the first try!
    I also had this connector at the very bottom of the closet with computer stuff . Don't know from what it is, it's only important that it's quite old :)
    Made the mount for it from the flat bar and welded it onto the top of the case. The pass for cables is also visible in this shot.
    All controller in place, final shots (of the controller, not the case!).
    Ouch there must have been a shorting in the circuit as there are several burnt cables :)
    View on the case, I think the controller completely change its appearance, didn't it ?
    TheGreatSatan and Asouter like this.
  16. Piotrek_PL
    29 Mar 2013
    Hey guys, do you see the pics? There's a problem with my server and some people from particular countries for example Argentina or US might not see them, don't know what's going on, my hosting support is working on it (at least they say they are..)
    If you don't see them please tell me what error do you get and where are you from, it will help solving it. Thanks!
  17. Pranja
    Pranja Blackwolf
    18 Dec 2011
    I have no problem with pics-they are fine.
  18. ry@n
    ry@n Minimodder
    31 Aug 2005
    Looking really good! I enjoy looking at how themed builds are put together, its not often you see a welder using on a case mod :D
  19. Shurika
    Shurika Minimodder
    9 Mar 2012
    That's pity I can't see any pics...
  20. Piotrek_PL
    29 Mar 2013
    Thanks! I hope more ppl will see the pics soon :)
    Yeah my server blocks some IP's due to safety reasons...need to change it asap, hope to fix it soon.
