Other Recommend me a cordless drill?
Discussion in 'General' started by Unicorn, 25 Dec 2012.
  1. Unicorn
    25 Jul 2006
    People of bit-tech, first of all happy Christmas! Hope you're all having a chilled and awesome day :thumb: Now, to business :D My (until now) trusty 12v Bosch cordless drill burned out about 2 months ago and I haven't done a thing about replacing it since, much to my detriment because I seriously miss it and have been tormented using the corded one for everything since! I'm in desperate need of a cordless for drilling & tapping, screw-driving, nut-driving and all manner of other cordless jobs. The Bosch is only just out of warranty, and in fairness to the thing, has had a pretty harsh life with me for the past few years. It was bought for about £120 in a B&Q sale and really doesn't owe me anything, but this time around I'd like to get something more powerful and especially with a bit more torque for nut driving. I used to work with a tradesman who exclusively uses Panasonic cordless drills and swears by them, and rightfully so. If you took the amount of use that mine had in the past 3 years and multiplied it by 10, you might get close to the amount of use that his two Panasonics get, with all four NiMh batteries getting charged at least once per day.
    So, what have you got? What's good and what should I avoid? I'm leaning towards the Li-Ion DeWalt and Panasonic ranges, and for the added power I definitely need to get something above 12v. Budget wise let's keep it under £300 so my wallet doesn't get stung too badly :worried:
    I'm hoping to order this at the start of January because I can't really face another week of installation work without one :rolleyes:
  2. Joey Propane
    Joey Propane What's a Dremel?
    26 Feb 2011
    Can't go wrong with DeWalt or Panasonic, but my preference was always with Hitachi and Makita, always found them a good deal lighter with all the same power and durability (DeWalt batteries are nut crushingly expensive as well).
    My 14v li-on Hitachi impact driver survived many falls from scaffold towers when I was doing ceiling fixing.:hehe:
    On that note i'd suggest an impact driver over a drill driver if screw driving and nut driving is what your going to be doing.:thumb:
  3. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Infinite battery life!
  4. Throbbi
    Throbbi What's a Dremel?
    10 Sep 2009
    Makita
    /Thread.
    I spent 5 years using assorted drills and other power tools as a ductwork fitter and in all that time the only tools I never had a problem with were Makita (well those and Gilbows but they're hand tools).
  5. Prometheus
    Prometheus Minimodder
    26 Jun 2004
    +1
    I have one that I use for work, takes all kinds of abuse and just keeps going, plus the batteries don't take long to charge and hold their charge when they aren't being used better than the older batteries so it's always ready to go.
    Only down side is the batteries on their own aren't cheap so make sure you get at least 2 with what ever drill you go for.
  6. Modsbywoz
    Modsbywoz Multimodder
    14 Oct 2009
    Makita all the way.
  7. Unicorn
    25 Jul 2006
    Ah, good point! I want one for nut driving because it'd make getting wheels on and off the car for cleaning etc a breeze, and should come in very handy when the project car starts as well. But can I have my cake and eat it? Can you have an impact driver and a drill/driver all in one? This kinda tells me no.
    Yeah I knew about Makita as well, one of the other fitters who worked for that tradesman I mentioned used a Makita as well and loved it.
  8. bigkingfun
    bigkingfun Tinkering addict
    27 Jul 2008
    18V Makita
    I have dropped mine on concrente from the roof several times, picked it up and went back to work. It is expensive, but you get what you pay for.
  9. jizwizard
    jizwizard Modder
    24 Dec 2010
    I use a Dewalt and its never let me down. But if you want something even more robust and expensive I would go with Hilti.
  10. Joey Propane
    26 Feb 2011
    And a gym membership. Hilti tools are THE heaviest i've ever used, I ended up throwing my 110v screw gun off a scissor lift because I hated using it so much, replaced with a DeWalt that was probably close to half the weight.:thumb:
  11. TheBlackSwordsMan
    TheBlackSwordsMan Over the Hills and Far Away
    16 Aug 2009
    I've a kawazaki 21v and it do the job.
  12. walle
    walle Modder
    5 Jul 2006
    They are all quality brands so you can't really go wrong with any of them. Pick the 18V you can get the best deal on.
  13. dynamis_dk
    dynamis_dk Grr... Grumpy!!
    23 Nov 2005
    Yeah like above, I've used most of the brands mentioned above over the years and still have a variety of Hitachi, Makita and dewalt cordless tools (not just drills) - to this day never had one fail on me so pretty happy all round. I'd personally look for 18v or higher (and availability of larger capacity batteries if needed) and keep a good watch on what BnQ do over this coming weeks as my local store does some good offers over holiday periods :)
  14. GeordieStew
    GeordieStew Minimodder
    7 Oct 2011
    Milwaukee. Spend the extra hundred quid or so. You won't regret it. Ever!
  15. Unicorn
    25 Jul 2006
    So, no votes for Panasonic at all then? :p I know where you're coming from with DeWalt and all the rest though, I really am the biggest believer in getting what you pay for! :thumb:
    [edit]
    Same set, £50 cheaper. Ooh...
  16. murraynt
    murraynt Modder
    6 Jun 2009
  17. Anxing
    Anxing What's a Dremel?
    17 Dec 2014
    I have tried out the Panasonic products but really not satisfied with the performance of it.
  18. Jumeira_Johnny
    Jumeira_Johnny 16032 - High plains drifter
    13 Nov 2004
    You joined in Dec 2014 and this is your first post? Wow, you must really not like that drill.
    I have a Dewalt 14.4v. It's ok. If I bought again, I would go Makita 18v.
  19. Unicorn
    25 Jul 2006
    Wow! Necro bumping threads Cheesecake! I eventually went with a DeWalt DCK290M2 twin pack kit with an 18V DCD985 hammer drill/driver and DCF885 18V impact driver with two 4Ah batteries. Both those tools and the many other DeWalt XR series 18V tools I've purchased and used since have served me extremely well so far and I have no doubt they'll continue to do so for many more years. Each of them handles whatever I throw at it every day, and I get the feeling a lot of the tools have power and performance in reserve.
  20. TheBlackSwordsMan
    16 Aug 2009
    Holy mother of zombiethread. And here I am, drinking my second cup of tea, while I could go to the nearest hardware store & buy my very own drill. To the car!
