Recommend the best cheap 550W PSU
Discussion in 'Hardware' started by CrOaKeR, 10 Oct 2005.
  1. CrOaKeR
    CrOaKeR Host warrior 4, Vengence!
    21 Feb 2002
    The latest in a long line of silly computer disasters is that my Q-TEC 550 blew up. Looking for a cheap/decent 550W to replace it ASAP. I am not a big OC'er so i don't worry about the voltages too much.
    What can you recommend?
    Thanks in advance...... :cooldude:
  2. atanum141
    22 Jul 2004
    how about spending a nice amount of £££ so that you can take it along to ur new rig someday???....cheap psu's are not good! they never put out wattages that they are rated for...
    on a related note i have my Antec Truepower for sale... http://forums.bit-tech.net/showthread.php?t=99300 :D
  3. Tim S
    Tim S OG
    8 Nov 2001
    Cheap and decent don't go together in the same sentence. Decent and well-priced do.
  4. Boswell
    Boswell Minimodder
    23 May 2005
    your spec doesn't look like you need 550 watts :/
    [Abit NF7 Ver 2]
    [AMD 2000xp, 1 gig crucial ram]
    [Ati Radeon 9800 Pro AIW]
    [2x WD SE 8 meg 120 gig]
  5. fatty
    fatty Minimodder
    12 Jul 2004
    I would say atanum141's antec would be your best bet
  6. CarlT2001
    CarlT2001 What's a Dremel?
    23 Jul 2004
    Seasonic are supposed to be good. Efficient and stable...bit on the pricey side though...
    CustomPC mag did a huge review of PSU's this month...quite scary that the majority of them did not even pass ATX specifications...
  7. hitman012
    hitman012 Minimodder
    6 May 2005
    Erm, you could run that system on a quality 350W PSU... anything from Antec, Tagan, Enermax, Seasonic, or Hiper would serve you well. If you really do need 550W for a new system or something, then Hiper do a 580W modular supply that's a bit cheaper than the competition.
  8. CrOaKeR
    21 Feb 2002
    Thanks for the info guys. I got the q-tec because i needed another PSU after blowing up a generic 250w when adding a 9800 pro to my system! I will probably go for a decent 350w, maybe an Antec.
    Cheers again :thumb:
  9. atanum141
    22 Jul 2004
    i got 2X Antec's avail for sale if you want..
    one 350w and a 480w PSU's avail.
  10. CrOaKeR
    21 Feb 2002
    I just moved into a new place and am low on cash......... but a little more on the credit card cannot hurt!
    I just new this would happen when i started looking about, just hit the buy button on a shiny new Antec Neopower 480 . :rock:
  11. CrOaKeR
    21 Feb 2002
    Ok, got the neopower!
    Installed it yesterday, its very quiet compared to the crappy qtec i used to use. All the auto fan controlling stuff is quite impressive too. It also has a 3 year warranty which should keep me in good stead for a few years yet.
    Initial impressions, Great! :thumb:
  12. Echo
    Echo What's a Dremel?
    10 Oct 2005
    Yea! what was even scarier was that out of 31 tested, 15 failed and 9 EXPLODED!
    Go to custompc.co.uk if you didnt catch the mag off the shelves... they usually post thier reviews online...
  13. MrSeanKon
    MrSeanKon Minimodder
    28 May 2005
    A qualified PSU at 450 Watts it is better than a noname 550 Watts....
    Antec are good but Enermax + OCZ are better. :naughty:
  14. hitman012
    6 May 2005
    I noted with interest that an Antec TruePower 350W has equal available +12V current to the Ebuyer Extra Value 650W, and what's more, the Antec will provide all 18 amps reliably, as opposed to smouldering.
  15. specofdust
    specofdust Banned
    26 Feb 2005
    330W antec. Nuff said.
    Edit: Just noticed MrSeanKons post, I would strongly disagree about OCZ and Enermax being better. OCZ are made from the same stock as Tagans which aren't as proven as Antecs or Enermaxes. But while Enermax have a great reputation, I've been hearing some serious rumblings that there have been some really bad recent batches, so I'd avoid them for a year or so.
  16. Firehed
    15 Feb 2004
    Any Antec is a safe bet. Don't cheap out on a PSU. Cheap PSUs blow up.
