Cooling recommended thermal paste
Discussion in 'Hardware' started by bazman24, 25 Apr 2012.
  1. bazman24
    bazman24 Minimodder
    29 Sep 2009
  2. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    I prefer Arctic MX-4. I think it's one of the best performing ones out there.
  3. RevDarny
    RevDarny Minimodder
    27 Oct 2011
    +1 :thumb:
  4. T2I3M
    T2I3M Minimodder
    13 Mar 2010
    Acrtic silver 5 does the job for me
  5. bazman24
    bazman24 Minimodder
    29 Sep 2009
    ok thanks theres so many different ones to chose hard to know which one to go for!
  6. noizdaemon666
    15 Jun 2010
    AS5 is marginally better at conducting heat, but I find it harder to work with. That's just me though. Either one, just don't get something unknown and stupidly cheap.
  7. feathers
    feathers Minimodder
    11 Apr 2009
    I currently use Arctic MX-4. It's guaranteed about 6 years or something. Can't remember.
  8. Tangster
    23 May 2009
    I'm also currently with the MX-4 crowd, I couldn't find my PK-1 tube when I last needed thermal paste.
  9. The_Crapman
    5 Dec 2011
    There's only a degree or 2 between them, but mx-s and ac5 are the beat and most midely used. I personally go for zalman stg1 as you 'paint' it on with a brush to both surfaces ensuring good coverage and really easy application.
    It's more important to make sure that you've got whatever you're cooling cover properly, as even the best won't work well if not applied properly.
  10. The_Crapman
    5 Dec 2011
    Dp
  11. Deders
    Deders Modder
    14 Nov 2010
    AC5 is good but there are better ones out there, paste has come on so much since AS5 was the standard that you might not recognise some products as paste.
  12. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Gelid extreme is the nuts
  13. markbrett64
    markbrett64 thanks to denial I am now immortal
    12 Jan 2010
    Another +1 for MX-4... though I've had some good results with Ceramique too... both are completely metal free.
  14. bleeper
    bleeper What's a Dremel?
    25 Apr 2012
    I just bought a Gelid Siberian cooler, it came with some paste in a little packet that looks like a packet of sugar.
    All it says on the packet is 'Heatsink Compound'. I assume this isn't the same stuff even though it's the same manufacturer?
    In answer to the original post I have to echo what everyone else says regarding the MX-4. There are so many other variables that could affect the heat but I've never had anything run hot with MX-4, and I am hardly the most careful installer in town :)
  15. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    I much prefer my thermaltake ChillFactor 3 only a degree or so behind the Arctic Cooling MX stuff, and it's nonconductive, so I can throw it in my GPUs when I get around to changing those.
  16. Instagib
    Instagib Minimodder
    12 Mar 2010
    Isn't MX-4 non conductive?
    ...or have I just made that up?
  17. .//TuNdRa
    12 Feb 2011
    Mx4 wouldnt appear to be nonconductive, judging by the dact I shorted a ram module with the stuff by accident a while back.
  18. TobletDanillio
    TobletDanillio Minimodder
    7 Jan 2012
  19. feathers
    feathers Minimodder
    11 Apr 2009
    Anyone using that metal reflow pad? The kind intel use to connect IHS to CPU?
  20. Williz
    Williz Minimodder
    9 Mar 2012
    I use AS5 as it's done me well on all my builds. Are there any pastes that are better then?
