Cooling Removable dust filters
Discussion in 'Hardware' started by ashchap, 13 Mar 2013.
  1. ashchap
    ashchap Member
    28 Feb 2005
    My HTPC case is the generally excellent Silverstone GD04. I love everything about it except for one thing:
    The dust filters are screwed onto the fans.
    So every few months I have to open up the case, unplug the BD drive and hard drives, remove the optical drive and hard drive mounting brackets, unplug and remove all 3 fans from the case, unscrew the dust filters, clean them and then put it all back together again.
    The whole process takes about 20 minutes, which is starting to become a bit of a drag so I was wondering if anyone knows where I can buy a set of 120mm dust filters that can be cleaned without having to remove the fans from the case?
  2. jinq-sea
    15 Oct 2012
    Scan have some - a colleague bought some recently. I'll see what they were and let you know, but I'm pretty sure they were these: Link
  3. Guest-23315
    Guest-23315 Guest
    I just use cut up bits of tights, held around the fans with an elastic band... seems to do the job perfectly.
  4. ashchap
    ashchap Member
    28 Feb 2005
    I like the look of those but what does the magnet stick to? (I still want them to be inside the case)
  5. jinq-sea
    15 Oct 2012
    They'll magentise to the case, or, probably easiest, just go between the case and fan and be anchored by the screw :)
  6. Captain Haddock
    Captain Haddock Blistering Barnacles
    21 Apr 2008
  7. zulu9812
    zulu9812 New Member
    21 Oct 2010
  8. ashchap
    ashchap Member
    28 Feb 2005
    Thanks guys, I might give them a go.
