News Researchers create photonic jet storage
Discussion in 'Article Discussion' started by CardJoe, 4 Jun 2008.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. bowman
    bowman Minimodder
    7 Apr 2008
    'The main drawback with commercialisation of the technology isn't in the manufacturing stage – the glass sphere required for the generation of the photonic jet is around two micrometers, well within current manufacturing capabilities – but in the execution: the sphere which focusses the light beam would be required to hover somewhere in the region of two hundred nanometres above the rapidly spinning disc without ever coming into contact with its surface. To put that into perspective, an average size human hair is 80,000 nanometres in width.'
    Uh - seeker heads on modern hard disks are twenty times closer to the platter than that. Give the tech to the HDD companies, they'll be happy to make it work and sell it. Maybe they'll get the platter drive to last longer against the SSD juggernaut.
  3. will.
    will. A motorbike of jealousy!
    2 Mar 2005
    Where do they get all those photonic torpedoes from?
  4. Dr. Strangelove
    Dr. Strangelove What's a Dremel?
    13 Mar 2005
    Hmm i think the biggest problem with the distance (and the biggest difference between drive platters and optical media) is that optical media is not all that stable we all know that CD/DVD's alter shape over time, so I guess an old disk in this system could hit the prism due to the material shifting. Also platters are solidly mounted inside a HD the same cannot be said for optical media, unless they use some sort of permanent caddies.
  5. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    now there's an idea....
    i would love to see holographic media take over.....
  6. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    Why does the disc have to revolve? Place the disc on a lens made of spheres that focuses the jet. Have the reader revolve relative to the focusing lens. This way the disc doesn't need to be mounted assuming the reader can compensate for the mis-aligment of the disc when it is inserted.
  7. johnmustrule
    johnmustrule What's a Dremel?
    12 Jan 2006
    -Because making disks out of spheres is both economically exspensive an the disk would only read where the spheres where focused eliminating the increased density given by the small wavelength beam and thus storage would go down in capacity instead of up.
    -Hardrives are exspensive to produce due to their precise nature and manufacturing optical media to such precision would negate the whole "bang for the buck" purpose.
Tags: Add Tags
