Rgb strips in my room
Discussion in 'Serious' started by chilliewillie, 18 Oct 2014.
  1. chilliewillie
    chilliewillie What's a Dremel?
    14 Apr 2014
    hi,
    i have rgb strips on my room, they are on my wall and they have 3m sticky tape on the back but 1 problem they dont stick[​IMG]
    how can i fix this?
  2. Comrade Woody
    Comrade Woody Obsolete
    14 Mar 2011
    The backing on those strips isn't very good. Just use some better double sided tape. I used 3M 4010 on the strip in my case but you'll probably want something thinner for on the wall.
  3. Xir
    Xir Modder
    26 Apr 2006
    Sometimes these LED strips get warm...not hot, but warm enough so the glue on the tapes comes off.
    Either use better tape, or mount them on an aluminum strip, or for better looks, an aluminum U-shape.
