Scratch Build – Complete Robocop Casemod - ED-209 by RandomDesign
Discussion in 'Project Logs' started by random2k4, 1 Sep 2023.
  1. random2k4
    random2k4 Multimodder
    11 Aug 2015
    And now for another mod.
    I worked together with the company Nacon to create a mod that
    should promot the upcoming Robocop game. So I decided to build the ED-209 from the original movie.
    The mod already was shown at gamescom. Unfortunately only in the business area.
    Now I got some time to finish the rest of the work and start the worklog already.
    I got some renderings from the video game.
    I took them as a reference to creat my own version of the ED-209. Many parts will be 3D printed,
    but others will be molded and cast in resin.
    Cause this specific version will be raffled away, my wife got the idea to directly build a version 2.0
    once this project here is done. Already got a long list with improvements and changes I want to make to this one.
    But first lets finish version 1.0 :)
  2. Monkey Puzzle
    Monkey Puzzle Minimodder
    18 Feb 2009
    "I think you better do what she says Mr Kinney."
    Looking forward to this. Nice modelling!
    random2k4 likes this.
  3. Vault-Tec
    30 Aug 2015
    I’d buy that for a dollar!
  4. Cheapskate
    13 May 2007
    Awesome! :D
    -Also, Where do you find a woman that cool?
  5. random2k4
    11 Aug 2015
    Once I met her, I got 40 seconds to comply.
    Cheapskate likes this.
  6. censored_Prometheus_
    censored_Prometheus_ Minimodder
    26 Mar 2019
  7. Vault-Tec
    30 Aug 2015
    40 seconds is quite impressive for the first time. It beats 20 seconds any way :D
  8. random2k4
    11 Aug 2015
    Then it was already time to start.
    I have worked on multiple pieces at the same time, but I will try to
    organize the pictures as good as possible.
    Sterted with the feet that are mainly printed in PLA.
    To reduce a little bit of the weight, the front and side pieces of the foot will be roto cast
    later, but the template is printed in resin.
    And most of the parts were done.
    Most of the parts from the leg will be attached to an inner core that will hold all the weight of the mod.
    Inside the inner core, I already included all the holes for the mounting. Will have more detailed pictures later.
    Then I started sanding down the layer lines in my PLA prints. I also gave the resin parts a quick sand.
    Even if they are printed in resin, a slight sanding will really improve the later apperance.
  9. censored_Prometheus_
    26 Mar 2019
  10. IanW
    IanW Grumpy Old Git
    2 Aug 2003
  11. random2k4
    11 Aug 2015
    IanW likes this.
  12. random2k4
    11 Aug 2015
    And here is a picture of the two parts of the inner construction of the leg piece.
    They will be just pushed onto a 2x2 cm aluminum profile. This already holds up püretty good,
    but I also included two 6 mm threaded rods just for a better mounting.
    This way, I dont have to glue any parts, but could theoretically make changes or take
    everything apart if needed.
    Then I printed all the pieces for the outer shell of the leg.
    First sanded everything with 120 grid sanpaper and then glued all together.
    Smaller parts were printed on my Prusa MK3S and the larger ones on my Elegoo Neptune 3 Plus.
    The Neptune is a decent printer for the price, but the parts need more post processing than the Prusa ones.
    All the larger gaps were filled with Miliput, a two part epoxy putty.
  13. random2k4
    11 Aug 2015
    Unfortunately, I just realized now that my camera messed up
    the white balance in some images....
    After the main construction of the leg was done, I started with the detail parts.
    Working on this little part on the top and bottom side of the leg.
    As I need most of the details multiple times and also in more or less the same look.
    I decided to make mold and cast them in a cold-cast technique. This way, I will save some time
    in the Post processing, and all the metal parts will have the same look.
    First, I printed both parts in resin. This alone saves a lot of time in post processing as resin
    sands much better than ABS or PLA. Also much less sanding is needed.
    Then I built a simple card board mod box. I used Mold Star 30 (not 20T) as my silicone.
    A simple one part mold was more than enough for this simple piece.
    For a cold cast, you first need to dust the mold with some metal powder brfore pouring the resin in.
    I used Smooth-Cast 305 for most of the pieces.
    The cast parts looked a little dull right out of the mold. After polishing with some steel whool
    all was nice and shiny.
    A quick weathering with a brown and black wax followed.
  14. random2k4
    11 Aug 2015
    The next detail were also first resin printed and processed.
    Cause the back side of this pieces was important, I needed to make a two part mold.
    First I made a clay bed and layed the pieces on top.
    After the first half was done, I simply needed to spray a mold relsase on everything and
    made the seconf half.
    And the entire mold was done.
    The larger detail parts was just cast in normal resin. The smaller parts were cast again with a cold cast technique.
  15. Idioteque
    Idioteque Telephasic Mongoose
    21 Aug 2004
    Can't wait to see the end result!
  16. random2k4
    11 Aug 2015
    Next, I worked on the mid sectinn of the leg.
    First all parts were again printed.
    I needed the cover on the side 4 times in total in metal optic. So I made a mold again
    and did a cold cast of all the pieces.
    While working on some parts, I realized that the back part of this section needed a very long time
    to get sanded down. So I made a little adjustment and printed that part also in Resin instead of PLA.
    That way I yould make a hollow cast of this part. UNfortunately, I missed taking some pictures,
    but I have some showing the process in a different section later.
    The next part, I also needed 4 times again, so I made a two part mold and cast everything.
    Again polished the cast pieces with some steel whool.
  17. random2k4
    11 Aug 2015
    Over time, I got quite some parts on my workbench.
    Luckily, I could print the arms as one piece on my printer.
    Minus the details ofc.
    For the rocket launcher of the right arm, I combined PLA and resin printed parts.
    The three cannons also have three magazins on the bottom part of the arms. To reduce weight and to fit the
    desig, they were also cold cast, but hollow.
    First, I prepared the master.
    I used Smooth Cast Onyx Fast, cause it only has a 3 minute pot live. Hat gave me enough time to poure it into the
    mold and rotate it to get the resin on every spot on the inside. After a partial cure, I repeated the procedure
    to get a little more thickness for the walls.
  18. random2k4
    11 Aug 2015
    To attach the arms to the main body, I printed some kind of ellbow.
    The holes are later used to incert a metal rod for stabilization.
    Cause the resin parts were too brittle, I decided to also make a mold and cast this section.
    Already predrilled the holes for all the screws and metal rods.
    Then, I could finally start building the "head" section. Just needed to cut it down
    to 4 pieces to fit on my printer. Makes filling a little easier.
    For stabilization, I glued two aluminum profiles to the inside.
    To further strenghten the section, I applied an epoxy coating to the inside.
  19. Cheapskate
    13 May 2007
    Super happy brackets
  20. random2k4
    11 Aug 2015
    They couldnt belive I actually use them for a project.
