Hardware Roccat Pyra Mouse Review
Discussion in 'Article Discussion' started by Lizard, 24 Jul 2010.
  1. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
  2. Jipa
    5 Feb 2004
    Not a word on the software or battery life? kinda disappointing, as the software adds functionality and the battery life is the only real deal breaker with this mouse.
  3. mrbens
    mrbens What's a Dremel?
    15 Aug 2009
    I'd like a wireless mouse+keyboard so I could play first person shooters and strategy games sat on my sofa with my 50 inch plasma with a small lap sized table for them to sit on :)
    Just like I do with PC games that use the wireless xbox360 pad.
  4. mrbens
    15 Aug 2009
    ooops pressed wrong button lol
  5. Gunsmith
    Gunsmith Maximum Win
    23 Sep 2005
    mouse and monitor are critical components worth spending top coin on. afterall you are using them everytime you boot up
  6. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    I bought a Logitech M505 for my laptop gaming - it's more comfortable than this Roccat looks.
    Also, no laser on this?
    By the way, it can be had for £25 (£5 less then Ebuyer) at Pixmania if anyone is interested.
  7. Dead Ghost
    Dead Ghost What's a Dremel?
    11 May 2007
    "While the lag-free connection might deteriorate over time(..)"
    Huh? How can this happen? You are saying that it's possible that the wireless connection might deteriorate, as time passes? Is this common with wireless mouse and keyboards?
  8. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    I found the wired 360 controller has a long enough cable for me to use from sofa distance. I have a wireless mouse/keyboard set, though mostly I only use the keyboard - the batteries last ages and input lag is less of an issue. I have a wired mouse for desk use.
  9. Yslen
    3 Mar 2010
    I think he means as the batteries begin to die.
  10. steve30x
    steve30x What's a Dremel?
    31 Aug 2008
    I have a Logitech VX nano and it has no lag even after having it for the past two years. How does the battery life compare on this mouse to my VX Nano? The batteries on my VX Nano need to be changed every six months even with lots of use (6 - 8 hours a day)
  11. Elton
    23 Jan 2009
    I think when he said the signal deteriorates he meant over time due to battery life loss.
  12. Denis_iii
    Denis_iii What's a Dremel?
    1 Jan 2007
    any wireless keyboard/mouse combo's bit-tech recomends? i'm sick of wired life!
  13. Blackie Chan
    Blackie Chan What's a Dremel?
    5 Nov 2009
  14. woody_294
    woody_294 Wizard Ninja :P
    31 Dec 2008
    Is it just me, or is this mouse listed as wired on both Scan and Ebuyer???
  15. Greatandyman
    Greatandyman What's a Dremel?
    23 Aug 2010
    It's not just you. After a search the wireless version is £49.99! Not pleased :(
Tags: Add Tags
