Cooling running a wc pump 24/7
Discussion in 'Hardware' started by harvy, 27 Mar 2007.
  1. harvy
    harvy Minimodder
    12 Apr 2006
    Whats the take from you people on running a wc pump 24/7?
  2. aquatuning
    aquatuning What's a Dremel?
    5 Jul 2006
    if its a good pump theres no issues in it at all ;)
  3. Nexxo
    23 Oct 2001
    Any pump suited to watercooling PCs is (or should be) rated for "continuous duty". That means it is built to run non-stop.
    Aquarium pumps in particular are designed to reliably run 24/7 for decades, but most other pumps that are sold for PC watercooling will also happily run for 50.000 hours (about 6 years) non-stop.
  4. harvy
    harvy Minimodder
    12 Apr 2006
    cool- sounds like my Eheim compact 600 pump from alphacool should last me a couple of years atleast then?
  5. Krikkit
    21 Jan 2003
    Should last a good while, check the datasheet out for it, if it's got a decent Mean Time Before Failure (30-50k hours, as Nexxo says), it'll do you fine. :)
  6. Nexxo
    23 Oct 2001
    Eheims in particualar, being German engineered high quality aquarium pumps, are designed to run continuously for decades. Only your heart is likely to last longer.
  7. naokaji
    naokaji whatever
    8 Dec 2006
    i've had an eheim 1046 running 24/7 without any problems for several months before i switched to a laing to save some room, the laing also didnt cause any problems yet.
  8. nry
    nry Minimodder
    1 Nov 2006
    Had a Eheim running solid for the last year pretty much, and it was 2nd hand.
    No problems at all. Makes a few noises now and again but nothing I worry about
  9. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    I built my own WC pump from solid aluminum stock as a practical study assignment for an engineering course at uni. Its about halfway between an Ehein and a Laing in size.
    been running non-stop for about 4 months so far. Its also dual-flow (twin input/output with no mixing), meaning I can have one pump driving two separate loops simultaneously. (cpu/ram;gfx)
  10. Nexxo
    23 Oct 2001
    Pics. You know we want them.
  11. Axel
    Axel What's a Dremel?
    20 Feb 2007
    oh i want to see them
  12. harvy
    harvy Minimodder
    12 Apr 2006
    I dont wanna see them, could you just send the pump to me instead?
  13. Bluephoenix
    3 Dec 2006
    I don't have access to a camera at the moment (with all the other tech around one would think it would be easy to get a decent camera) but when I have the time to drag it out and have a camera I should be able to post some. dunno when, as spring break here just finished. It is currently in the box I do most of my work on I can't afford to tear apart the LC system for the 2/3 days it would take to drain/remove/refill/recheck/reinstall the loop.
    @harvy - if I had the time, I'd offer to build you one, but at uni time is the most precious of all commodities.
  14. Axel
    20 Feb 2007
    woah,when i just look at your "media" server...
  15. Fibbles
    Fibbles What's a Dremel?
    22 Apr 2004
    I've been using the same Innovatek HPPS (made by Eheim to Innovatek's specs) since 2003 and it's running well (the same as it was from day one).
  16. olly_lewis
    olly_lewis What's a Dremel?
    19 May 2006
    I've ran watercooling systems for 24/7 in the past and ive seen them go for much longer than that... but it all depends on the water cooling gear you're using.... if its cheap as chips then it might not be so smart to keep it running all night....
  17. Bluephoenix
    3 Dec 2006
    @axel - its not just a media server really, I use it for other work when the main rig is doing CAD analysis
  18. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
    :D Thats good to know, i always worry a little when i go out for the day, and leave my pc downloading. I have seen the results of a watercooling system after the pump fails, and the pc is left ticking over. not nice :p
  19. Axel
    20 Feb 2007
    what could happen if pump dies?
    There wont be leaks i guess and your cpu will shutdown when it reaches maybe over 60
  20. Bluephoenix
    3 Dec 2006
    one trick I picked up from a friend is if you're using a DC pump to hook it into the power switch, that way if the motor dies, the computer will turn off. It saved my friend at least $3000 about two months ago when his pump motor failed. (he was running a 'cheap as chips' job)
