Windows S.T.A.L.K.E.R- slow frame rate after 1st misson
Discussion in 'Gaming' started by Thierry, 26 Jul 2008.
  1. Thierry
    Thierry What's a Dremel?
    20 Jul 2008
    hey
    i just bought stalker.... it plays well got it on "maximum" settings at 1680*1050 abd get over 30fps throug out the first misson but after i go and deliver the flash stick to the guy thats saves u the frames drop to around 18-20~ once u get back outside.
    anyone else haveing this problem ? and how would i make it more playable
    rig-
    Gigabyte p965 ds3
    E4300 @ 2.7ghz
    2gb 800mhz geil ram
    1x160gb 1x500gb
    Geforce 8800GT
    Thanks for ure help
  2. Krikkit
    21 Jan 2003
    Have you installed all the patches? They added quite a few bug-fixes and performance increases.
  3. Thierry
    20 Jul 2008
    can u patch them even if u have bought and downloaded it through steam ?
  4. GoodBytes
    20 Jan 2007
    Of course you can, how silly would that be that you can't. As long as you purchased the software their should be no problem.
  5. Thierry
    20 Jul 2008
    ok... i just thought cos its steam they would update it for u as they do for css, hl2 etc
    but cheers will apply the patches
    Thierry
  6. Thierry
    20 Jul 2008
    hm i tried patchen it but it says that it is already patched up to 1.000500... but i dont think that it is on.
  7. Krikkit
    21 Jan 2003
    Seenas it's from Steam it's likely to be the latest version. The only thing I can suggest is reinstalling your graphics drivers and the game... :(
  8. GoodBytes
    20 Jan 2007
    by re-installing he means to uninstall the old drivers first and install the new ones. You might need to disconnect from the internet to prevent Windows from getting the drivers from Windows update.
  9. Thierry
    20 Jul 2008
    i have the 175.16 drivers installed and i have installed the game about a week ago so i dont think thats the drivers thats the problem
    Thierry
  10. Smegwarrior
    Smegwarrior Fighting the war on smeg
    19 Nov 2007
    If you have STALKER: Shadow of Chernobyl then there is a patch version 1.0006 but it is not available from the STALKER website, you have to look on the website that they use to host the patch files (Fileplanet or whatever it is called).
    I have not been able to get any of the mods, that players have made, to work though.
