News Sandforce SATA 6Gbps SSDs sampling in Q3
Discussion in 'Article Discussion' started by Sifter3000, 16 Jun 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    great news, but i will wait for the second revision thanks (price permitting)
  3. V3ctor
    V3ctor Tech addict...
    10 Dec 2008
    Time to sell my Intel X25M 160gb... before it becomes too cheap :)
  4. tristanperry
    tristanperry Minimodder
    22 May 2010
    Will be very interesting to follow this one. 520MB read and write would be pretty exceptional. I wonder what it'll be priced at? (>£3 per GB?)
  5. mi1ez
    mi1ez Modder
    11 Jun 2009
    We'll be limited by NAND speeds surely? not to mention the price of NAND that will operate at those speeds. Bet these'll be SLC only...
  6. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    I like the sound of this, but I have a few questions.
    1) Will the NAND become a bottleneck if the controller is that fast? How fast (in theory) can NAND be written to?
    2) Will they be using this chip to make small fast cheap drives, or make the same mistake as current manufacturers who make large higher priced drives that people can't afford? (technically I guess that's not down to Sandforce.)
    3) A General question. How easy will it be to clone my OS on my current HDD to a new SSD? I hate doing fresh installs. I guess Acronis True Image can do it?
    4) Will it support TRIM? I'm assuming so, but a confirmation would be good.
    It'll be interesting to see what Indilinx have up their sleeve to combat this. They must have had time to develop a new controller since Barefoot came out.
  7. Skiddywinks
    Skiddywinks Minimodder
    10 Aug 2008
    I wish companies would be more open about their random read/writes. Sequential speeds are all well and good when cloning drives, copying across large (or lots of) files etc, but the real difference from moving to an SSD is the crazy increase in random speeds.
    Last time I checked, Sanforce were ahead of Intel's current G2 drives in randoms, but with Intel's G3 coming out in not too long, it would be really nice to see some random speeds, instead of the "Just put the biggest numbers out" approach.
    It should be interesting when both drives are out.
  8. Evildead666
    Evildead666 What's a Dremel?
    27 May 2004
    If the NAND isn't fast enough to switch at that speed, you add channels.
    More channels = more throughput, at the same switching speed.
    My lowly 30Gb Kingston drive with Toshiba controller has 4 Channels.
    The much better indilinx Barefoot et Al have 8 channels I think.
    This will prob be 16 or 32 channels...we'll see ;)
  9. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    To answer your question #3
    You will want to use a disk cloning software. The simplest one I found was
    "xxclone" just google disk cloning.
  10. MSHunter
    MSHunter Minimodder
    24 Apr 2009
  11. bob
    bob What's a Dremel?
    15 Dec 2009
  12. l3v1ck
    23 Apr 2009
  13. l3v1ck
    23 Apr 2009
  14. borandi
    borandi What's a Dremel?
    27 Jan 2010
  15. robots
    robots What's a Dremel?
    27 May 2010
    Nice. Keep them coming, bigger, faster, cheaper. Maybe in 6 months I'll finally buy one.
  16. TomH
    TomH BELTALOWDA!
    28 Nov 2002
    Still ~£2/GB, which is what it's been for a while.
    There are many faster 'SSDs' that use a direct PCI-E link (OCZ have released products, ioDrive was one of the first if not 'the' first - just don't look at the price!) and use various types of NAND, number of channels and type of controllers.
    It's encouraging and daunting to hear that the 'next generation' are already slated to hit the maximum throughput of SATA 6Gbit and perhaps that's why OCZ were showing off more products for by-passing the SATA/SAS ports on the motherboard.
    Exciting times. Still, a 30GB SSD is still too expensive when you think about it. :(
  17. Ficky Pucker
    Ficky Pucker I
    9 Jul 2009
    just as i was ready to finally get a SSD, i'll wait a bit more then, maybe prices go down (probably not :( ) or something.
  18. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    I'm waiting till trim is internal or standard and not OS dependent and works in RAID
  19. iwod
    iwod What's a Dremel?
    22 Jul 2007
    I was expecting 6xxMB/s, i guess i was expecting too much.
  20. boogerlad
    boogerlad What's a Dremel?
    27 Jun 2009
    you can't go higher than max theoretical.
Tags: Add Tags
