Sc4mpi's V1000SLi - Stage 1 done.
Discussion in 'Project Logs' started by sc4mpi, 17 Jan 2005.
  1. sc4mpi
    sc4mpi OG watercooler
    16 Jan 2005
    Not yet aint got around to fitting blocks or testing cards as cpu aint arrived
  2. nissmo300
    nissmo300 What's a Dremel?
    19 Aug 2004
    You should some black trim around the edges and it'll look MUCH better :D
  3. cfuk
    cfuk What's a Dremel?
    9 Jul 2004
    have you got a link to where you got them fans from :clap:
  4. Dean_j2001
    Dean_j2001 What's a Dremel?
    1 Apr 2003
    let me just point out
    yer www.ebuyer.co.uk as he said, please take some time to read what he says :search:
    or if your really lazy
    http://www.ebuyer.com/customer/prod...2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=65697
    took 1minute to find
    :wallbash: :search:
    actually in my personal appnion i disagree, the case is made purely from alluminium, why put a piece of plastic c molding round and ruin the whole theme. You can purchase a c molding made from metal. or deburr the edges of the cut and clean them up.
  5. cfuk
    9 Jul 2004
    i know he said ebuyer :wallbash:
  6. rowan57
    rowan57 What's a Dremel?
    14 Dec 2004
    Sorry, also disagree, the lines are lovely and clean at the moment, black trim would spoil this
    Awesome project btw
    Rowan
  7. sc4mpi
    16 Jan 2005
    Ehehehe Cpu has arrived i cant wait to fire this monster up. :D
    But before i can do that fittings for watercooling need to arrive :)
    p.s The holes will be cleaned up when i next remove the motherboard but i dont realy like the idea of black trip cause
    1. case isent black
    2. at moment the top of the case is flat exept for the bolts the grill done come out the holes they fit perfectly :)
    P.s any marks on top of case is just dust btw from were its been sitting on my shelf
    Sc4mpi out...
  8. Dean_j2001
    1 Apr 2003
    exactly scampi much respect to you and your work, my appnion
    if you make a good enough job of a cut why should you cover it up and my appnion it looks like a lovely job of cutting out the holes :)
  9. -Enforcer-5716M4
    -Enforcer-5716M4 What's a Dremel?
    1 Sep 2004
    True, true... But it's "opinion" not "appnion"....
  10. Raymus
    Raymus What's a Dremel?
    29 Jun 2004
    That may be the cleanest home made cut ive yet seen. No way I would add black rubber trim around it. BTW what are those bolts you have mounting the fans in? Where can I get some. And do they thread into the plastic fans like normal screws?
  11. Blackfish23
    Blackfish23 Minimodder
    13 Oct 2004
    Awesome mod man. Have just convinced me too get a triple 120mm radiator new water cooling setup to go in my new mountain mods UFO case!
    Just wanted to know how noisey the fans are as im about to put around 7 120mm fans in one system!! And there a good price too :thumb:
  12. OdDBaLL_MoD
    OdDBaLL_MoD Always planning something...
    13 Sep 2004
    Cracking case! :rock: Looks absoluty great :D
  13. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    Looking sweet so far :), keep going little one.
    /me wants upgrade
    "curses phone"
    /edit
    Forgot too mention and ask on msn and well the thought just popped into head can you measure from the last fan on too the last fan hole on the triple rad and and tell me pls i'll edit my grill design and make one that works with the Thermochill rads :)
    Thanks
    Morgan.
  14. sc4mpi
    16 Jan 2005
    There M5 allen head bolts (got them from screwfix 50 for 2.40 :D )
    There can be screwed into a normal fan , but i taped the holes first with a 5mm bit so the bolts glide in very nicly, plus the heads dont thread :)
    The ebuyer fans are quite loud with 7 of them at 12v, i used to run them all
    at 7v and 5v which they were uterly silent, if u can rig them into a fan controler then they will be fine :) (ow that remindes me , need to get some form of fan controler for this project)
    P.s sure thingy morgan just tell me were u want me to measure or if not ill just bring the whole things round yours.
  15. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    Looks real sweet and clean nice one!! Love the screws on the rad...
    - S
  16. koegsmk
    koegsmk What's a Dremel?
    31 Aug 2004
    I alway use M4 bolts, they fit with no need to do something. :yawn:
  17. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    really nice job u done here. gonne watch closely here. keep on modding :dremel:
  18. scooby
    scooby Minimodder
    3 Mar 2004
    Very nice setup so far. What did you use to cut those 3 120mm holes on the top of the case? Very clean.
  19. sc4mpi
    16 Jan 2005
    I have some M4 bolts, but they wernt long enough and they dint seem to hold the fans in very well the M5's give a very nice tight fit, perfect for holding that heavy rad nice and steady :)
    HOLES WERE CUT WITH A 118MM HOLESAW
  20. sc4mpi
    16 Jan 2005
    right iv been looking at how im going to tube this whole thing up and so far come up with two plans. :)
    1.
    Dual bay res -> hpps pump -> Innovatek xx-flow rev 2.0 ->
    Thermochill 120.1 -> NV-40(1) -> NV-40(2) -> thermochill 120.3 -> graph-o-matic -> bk to res.
    2.
    This is the plan if i add my extra radiator
    Dual bay res -> hpps pump -> Thermochill 120.1 -> Innovatek xx-flow rev 2.0 -> Black ice Pro -> NV-40(1) -> NV-40(2) -> thermochill 120.3 -> graph-o-matic -> bk to res.
