Build Advice Scan.co.uk and returns
Discussion in 'Hardware' started by giskard, 7 Jan 2010.
  1. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    From the sounds of it, I would say scan are doing nothing wrong.
    They are agreeing to replace the product which was damaged due to installation under scansure. Once you've got this replacement you could then sell it as brand new, so you shouldn't lose too much.
    What is the item if you don't mind me asking? I mean if we're talking about something dirt cheap then I think your making too much of a fuss, if its something worth quite a bit, then the situation may be slightly different.
  2. erratum1
    erratum1 What's a Dremel?
    30 Apr 2009
    So first you ordered the wrong part, and then you damaged it.
    doh ! Perhaps stick to pre-built ?
    I've not used scan but if i ever got burnt by them i just wouldn't use them again, it's a fierce market and their's plenty of other e-tailers.
  3. GregTheRotter
    GregTheRotter Minimodder
    9 Aug 2008
    That's what I don't understand. If you had just asked for a refund from the word go, and not told them that it wasn't compatible, or that it was your fault, then by all means they should give you a refund. I mean, if you told them about it within those 7 days. Then fine. But the minute you made the mistake with ordering the wrong part, and you damaged it well, that's that isn't it.
    Thing is, call me a sneaky sod, but if I bought a part for my PC, and I managed to fry it, or damage it, where it wasn't clearly visible that I had caused the damage, then hell, I'd get on that phone and tell them it was dead on arrival, and that I want a refund.
    Oh well.
  4. giskard
    giskard System builder
    21 Nov 2009
    Thanks for the patronising and ignorant reply.
    I was told by Scan customer services that the part would be compatible with my system and so purchased it on that basis.
    For the record it's a Corsair H50 water cooler.
    The damage was a result of the product including two sets of mounting screws which look the same but have slightly different threads, but the instructions don't mention the two sets of screws, so I ended up using one incorrect screw and ended up stripping one of the female threads of the plastic rear mounting plate. A number of people have reported the same problem with the H50 since Corsair introduced the new (cheaper) plastic rear mounting plate.
  5. giskard
    21 Nov 2009
    I agree. The reason for my original post is to point out that Scansure isn't all it seems, but I'm glad that I took it out when I purchased from Scan because it's a lifesaver (well, a money saver really).
    It's a Corsair H50 water cooler - sixty quid new.
  6. evoyear
    evoyear What's a Dremel?
    10 Sep 2008
    roughfly idea, I think scan might solve the issure more flexible rather than just get rid off.
    he paid the service, if there is anything wrong, they can help to solve, not saying, I can;t do this, I can't do that.
  7. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    Im confused are scan not replacing the part you broke under the scansure insurance??
  8. Teelzebub
    27 Nov 2009
    I'm just curious what platform are you useing cos that cooler is compatible with all the following LGA775 / 1156 /1366 / AMD2/ 2+ / AM3 which cover's most of them
  9. Digi
    Digi The not-so-funny Cockney
    23 Nov 2009
    If it's only a stripped screw can't you just bodge a solution and cut yourself the hassle? And the H50 is compatible with practically everything... which system are you mounting it on?
  10. adam_bagpuss
    24 Apr 2009
    thats good point isnt.
    its runs on 775/1366/AM2/AM3
    not sure about 1156 though is that what u have ?
  11. 13eightyfour
    9 Sep 2003
    The original corsair H50 doesnt have a 1156 bracket, although corsair will send 1 if you email them. The updated H50-1 has brackets for all sockets iirc.
  12. Oclocker
    Oclocker What's a Dremel?
    21 Jun 2001
    Gotta say - Scan been fine here. At the point you activated Scansure you nullified DSR. Thankful that scansure saved you money, you want Scan to refund? But sorry that's getting crazy. By activating scansure you can't get a refund.
  13. giskard
    21 Nov 2009
    That's my point.
  14. giskard
    21 Nov 2009
    LGA1366 and it is compatible, but once the radiator is fitted, I can't shut my case side-panel.
    Before I ordered the H50, Scan's tech support guy assured me that the H50 would fit in my case.
  15. adam_bagpuss
    24 Apr 2009
    what case do you have ?
    which way did you mount the radiator ?
    is a fan in the way or just that the width of the radiator is too much
  16. Teelzebub
    27 Nov 2009
    Can you not move it a bit , As I said earlier I've had similar problems with their tech which is why I always record the conversations I have with them so they cant deny what they said
  17. 13eightyfour
    9 Sep 2003
    Do you have a really small case? Ive got a H50 cooling my HTPC and it fits in that no problems at all.
  18. Oclocker
    21 Jun 2001
    rubbish - you have no point - goods arrived & you damaged them. So DSR now 100% not applicable & yet you still want Scan to protect you. You should take the scansure replacement - make the best of it & just stop bleating IMHO. Sorry to be so blunt but Scan being talked about as the bad guys here is just wrong.
  19. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    Spot on mate.
  20. giskard
    21 Nov 2009
    How am I talking about Scan as the bad guys?
    Maybe you should read my posts in this thread more carefully?
    Given the circumstances (as detailed in my posts here) I'm unhappy that Scan won't consider a refund of the item that they recommended I purchase but doesn't fit my case, but I don't see how I'm slagging them off or bleating about it, I'm just pointing out what has happened (hopefully) for the benefit of others in this forum who might some day find themselves in the same position.
    You're not a Scan fanboy (Scan-boy?) are you?
    :eyebrow:
