Case Mod - In Progress Schwarz Mirror V2.10
Discussion in 'Project Logs' started by WeisseS, 7 Jul 2010.
  1. WeisseS
    WeisseS Italian Modder
    24 Sep 2007
    Hi guys!!
    I'm Francesco,a moderator of an Italian Modding Community and this is my first work-log here at bit-tech.
    First of all a special thanks to the sponsor that believed in this project: Enermax Italy and Plexishop.it (an italian company specialized in making and working with plexiglass)
    At the moment i' m looking for other sponsor
  2. WeisseS
    24 Sep 2007
    I realized some sketch with illustrator even if differents solutions goes around in my mind, both for the front and top side of the case
  3. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    dislike thumb nail images!
  4. WeisseS
    24 Sep 2007
    After this short overview of the project I want to show you the package arrived from Enermax
    Some fans.....
    Some Fan
    There are six silver apollish and two white cluster
    Two models in details
    Very nice but...have a look starting from the Apollish
    Turning on the switch you can see a nice light effect on the blades, thanks to 15 smd white leds.
    The fan is provided with standard sensor for termal and rpm control.
    Frankly speaking the Aplossih are my favourites, and they'll make a good impression once fixed on the radiator
    Fans Cluster, Unlike the Appolish, have standard leds on each corner... but enough to light up the whole surface
    The detail of the Enermax logo engraved on the alluminium frame
    The PSu, Enermax Revolution 85+
    The keyboard, an Enermax Acrylux low profile
    Last but not least they gave me also a jacket.
    That's all...
    Ok, I'm ready to start
  5. Heki
    Heki What's a Dremel?
    20 Nov 2005
    I'm ready to watch :rock:
  6. WeisseS
    24 Sep 2007
    Let's start from the making of the chassis!
    I bought four angular alluminium brackets with this spec:
    1mm wide
    2 mm large
    1 meter long
    with a particular chromium finish
    I'll cut each of them at half size in order to obtain eight brackets
    I marked each brackets with adhesive tape at the cut point
    Here they are... eights brackets 50 cm long
    I used liquid steel to temporary fix the brackets, but dont' worry in the next step you'll see some rivets ;-)
    This is the first frame where the side panel will take place
    Pliers removed....
    As i told you before, just to strengthen the chassis ,I used some rivets....but mounted with the "head" inside the frame, simply because I want the inside of the case as "clear" as posssible .
    On the other side the rivets "spikes" will be hided under the plexi cover.
    Both the upper and lower brackets will be at sight
    Two standard angular plate helped me to join the frames
    That's all, see you soon and stay tuned!
  7. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    All your image links in the 2nd post are dead = :(
  8. WeisseS
    24 Sep 2007
    Are you sure? I can see all images
  9. General_Confusion
    General_Confusion Now Where was I?
    3 Jul 2010
    I can't see them either.. (on a system at work anyway) :miffed:
  10. Mino
    Mino Ganzerli Mino
    5 Sep 2006
    Ok, I'm ready to read and comment this worklog , go on Weisses :)
  11. WeisseS
    24 Sep 2007
    Can you tell me the step where you can't see the images? Thanks
  12. StEm
    StEm What's a Dremel?
    30 Nov 2009
    im thinking it will be because hes at work, some peoples workplaces block the images on here.... i can see them. nice start btw..:thumb:
  13. WeisseS
    24 Sep 2007
    Thanks a lot Steam
    In the next photo you can see the chassis completed!
    The rivets' "spikes" are outside.... as I told before, will be hidden
    The lower and upper brackets are very reflective and quite a sight so I decided to leave them uncovered
    Rivets inside the case. Even the head will be covered by mirrored plexiglass
    The bulkhead must fit togheter with the lower profile so I made a 1 mm stair in the corner
    This scales is it between the two angle irons that will serve to me in order to create the unevenness from 1 milimeter in order to make to join to thread the bulkheads and to leave the chromium plateed profile me to par of the same one
    Top view of chassis.
    For you info.... 50 cm Height, 22 cm wide and 50 deep
  14. Dudey109
    Dudey109 Minimodder
    20 May 2010
    Looking good so far, I really like the fans, very nice :)
  15. WeisseS
    24 Sep 2007
    Let's take a smoked plexy plate
    I removed the cover to check transparency level
    ....and cheked if measures were ok by fixing it to rear side of the case
    It's time to came out some exagonal M3 bolts and the thread cutter
    Before threading I've doen some drills on the chassis' sides
    Plate screwed and cover removed !!
    It looks nice
    More plexi layers will be screwed with the bolts running out from the chassis
    Have a look at the internal details.
    The plate fit togheter perfectly with the profile
    The mobo-tray is reflective too but the cover is already attached to avoid from scratches
    Mobo-tray placed in diagonal
    A rear view of the mainboard.
    Here will take place the PSU, pump and hard disks
    Rear view of smoked plexi
    Frontal plate spec: 50x 22 CM
    7 drills on each side
    Top view of mirrored plate
    This a picture of the mirror plate, taken trough the smoked one
    Maybe you can understand better from this view
    Now it' s clear, isn't it?
    At the end a nice shot of the whole chassis with front and rear plate screwed
  16. maximus09
    maximus09 Forever n00b
    8 Jun 2009
    wow thats reflective, should make the inside of the case look bigger! but also will double up any clutter, but I'm sure you will have perfect cable management!:thumb:
  17. WeisseS
    24 Sep 2007
    Thanks Maximus,
    onestly all the cables will be hidden under the mainboard plate and only few cm will be uncovered but sleeved.
  18. logan'srun
    logan'srun following the footsteps of giants
    22 Apr 2008
    wow, you normally hear that 'google is your friend' but I must say, google translate is not your friend. There are so many bad translations I don't bother with your comments anymore, only look at the pics.
    GJ so far, will be interested to see how you envision the mirror effects!
  19. Guinevere
    Guinevere Mega Mom
    8 May 2010
    But you're missing half the fun ;)
  20. WeisseS
    24 Sep 2007
    Sorry for my bad English :wallbash:
