Scratch Build – In Progress [Scratch Build] 'Completed' Project Ethos & Cube - The Baby Grand
Discussion in 'Project Logs' started by SavellM, 19 Mar 2013.
  1. SavellM
    SavellM What's a Dremel?
    19 Mar 2013
    So we start out today with a SSD sandwich.
    Double sided taped together.
    All SATA cables made and fitted:
    Doing a dry fit run on the lid:
    Piano hinge screwed down:
    All snug:
    Test glass fitting:
    Drilling into the lid, but why?
    What's this shiny beast, you will see soon:
    Grommet cut out and fitted:
    Yup nice monitor arm:
    Lid is silicone'd into place:
    New monitor attached:
    Fits like a glove... You can also see all the mess I have made, oops:
    Testing it out... So pwetty:
    Nice ultra wide monitor, works nicely:
    Its actually really comfortable sitting here:
    And a nice celebratory drink, for a job well done :)
    Testing it out:
    Gotta finish off the cable management. But the buttons look good :)
    Quite a nice arm:
    And the finishing bottle :)
    There are still little bits to get done.
    Like I haven't connected any of the LED's under the mobo, as I want to control the lighting if possible so its not too bright.
    The network cables aren't in the correct place.
    And just general bits and pieces here and there.
    I will also get some professional pictures done once its completed!
    Its been about a year almost but its so worth it.
    Phame likes this.
  2. spyplane
    spyplane What's a Dremel?
    12 Nov 2013
    Amazing. That looks like a godly setup, grats!
    Question, what molex kit did you use for the HDD/SSD power? I would love to make a custom setup for my own build.
  3. l3p
    l3p www.^.nl
    1 Nov 2010
    Totally love it!
    One last thing I would do which will look awesome in this build .. remove the red HDD stickers :)
  4. SavellM
    19 Mar 2013
    Thanks mate :)
    The Molex are from kustompcs.co.uk
    And I make them myself.
    The SATA connectors are from MDPC
  5. SavellM
    19 Mar 2013
    Thanks Peter!
    Its a great honour coming from you... You were one of the main inspiration's for me to actually do this. I love your desk, so I had to do one for myself.
    And yes, I still have some little things to do to finish it off.
    And removing the stickers is one of them :)
  6. l3p
    l3p www.^.nl
    1 Nov 2010
  7. SavellM
    19 Mar 2013
  8. Phame
    Phame COOOOFFFFEEEEE
    17 Sep 2012
    Dude this is a excellent mix of carpentry skills and nice hardware choices.
    The fans that are on the angle near your left leg, are they push or pull?
    I ask this as I would have put fans on the other side of the rad as it looks rather bare.
    But it is an awesome piece of work my friend.
    Well done!
    +Rep! :)
  9. SavellM
    19 Mar 2013
    Thanks buddy :)
    Ye they pull air from inside the desk and expel it out.
    I kinda wanted the bare look, but this is all stuff I can work on in the future.
  10. SavellM
    19 Mar 2013
    Soooo....
    I was thinking of taking of taking off the Sabertooth armour and spraying it white.
    You can see it here in this pic:
    Anyone have any thoughts?
  11. Cheapskate
    13 May 2007
    Leave it black! Other than that, cover that stock fan logo and Ni-doc the drives, -probably easier than sticker removal. You might want to figure out what drive letter each one is and label them.
    Anyway, Looks fantastic.:D The rest of the room will just have to stay dirty now that you have a running 'pooter.:lol:
  12. SavellM
    19 Mar 2013
    A little taste on what I have been working on currently...
    Its going to take awhile before I'm fully done with this, but I think the results will speak for themselves.
  13. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    So... almost 4 months later and...?
  14. SavellM
    19 Mar 2013
    Hehe sorry man.
    Started a new job and lots of changes.
    Project isn't dead.
    Still need to finish up the cable stitching (man what a pain).
    I have clean out the loop and changed to a UV Blue now, will take some pics.
    Got a UV strip as well and a switch for it.
    So need to mount both of them.
    But I'm thinking of changing to UV Green soon (for team green).
    Got a few more cables to tidy up and hide away.
    But hopefully should get some proper pics done in April if my brother in-law comes around.
  15. SavellM
    19 Mar 2013
    Update time...
    LED RGB strip installed, and testing it out:
    Empty out the loop and install a drain line:
    5x HDD's in and stickers removed:
  16. SavellM
    19 Mar 2013
    Then some chiseling time:
    Some cable tidying...
    Decided to forget the stitching as there were some really awkward areas.
    UV LED installed:
    UV LED switch:
    And some pics as it is now:
    That's it for tonight :)
  17. TheViscountGodrich
    TheViscountGodrich Wannabe modder.
    12 Apr 2014
    Probably my favorite desk build yet.
    subbed.
  18. Shurika
    Shurika Minimodder
    9 Mar 2012
    Well done! Don't you mind Alu in the motherboard radiator? It could give you some problems in a few years
  19. SavellM
    19 Mar 2013
    Thanks matey :)
    I love it too.
  20. SavellM
    19 Mar 2013
    Its already giving me problems...
    So I have a EK mobo block to replace it with.
    Just waiting for the Mayhems Blitz cleaner to arrive and some different colours to test out.
    Then I will yank it all out and replace the mobo block, and maybe run a loop around to the south bridge. It could look pretty good, but be difficult to bend around the GPU without obstructing the 5.25" bays.
