Modding Short addressable Led strips?
Discussion in 'Modding' started by Mojo, 25 Aug 2023.
  1. Mojo
    Mojo Multimodder
    18 Nov 2011
    Hey Folks - where can i find short addressable led strips? pre-assembled? thinking 10cm - 15cm?
  2. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    The longer ones can usually be cut down at certain places along their length.
    Arboreal and The_Crapman like this.
  3. The_Crapman
    5 Dec 2011
    Amazon is your best bet, although difficult to find any under 30cm. You can always snip them to length. There's always little contact patches for soldering every 3 LEDs or so that you can cut them at
    Arboreal and IanW like this.
  4. Arboreal
    21 Jan 2011
    I had a look at the per metre ARGB strip at Pimoroni, they offer 3 densities of LED which is nice. The 3 pin connectors they offer wouldn't work with a PC ARGB header as they are 4 pin with a blank, so you'd have to make something up for the PC end.
    You could probably make 5 or 6 for about £20, soldering them up yourself.
    My new board has no LEDs or a power/HDD light, so would consider a 15cm strip myself
  5. Mojo
    Mojo Multimodder
    18 Nov 2011
    Ahhh i didn't know that they could be shortened like the normal Led strips!
    Thats handy to know!! :)
