Build Advice Should I? 950--->2700k
Discussion in 'Hardware' started by HandMadeAndroid, 24 Jan 2012.
  1. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    Current build:
    haf x nvidia edition, i7 950, noctua cooler, asus sabertooth, 12gb ddr3 1600, HX 850 corsair modular PS, Asus 580GTX direct CU, 128gb crucial 6gb/s SSD, 2TB western digital black 6gb/s
    Proposed upgrade i7 2700k, Asus P8Z68-V PRO GEN3 Intel Z68, Corsair Dominator 16GB (4x4GB) PC3-14900C9 1866MHz . maybe 850 80plus PS (Corsair Professional Series AX850 High Performance 850W Modular '80 Plus Gold' Power Supply)
    Here's my thinking: the CPU charts score the current i7 much faster than the 950. (around 20%) , while it consumes a lot less energy (my energy bill is massive!) I make 3D models so often max all the threads out rendering as well as using 2D applications such as photoshop and illustrator. I was thinking I'd probably get around £300 for my current board, cpu and RAM so the upgrade wouldn't totally kill the old bank balance. Also is is it worth getting an 80plus power supply to replace the 'HX' And finally if I went ahead would the NH-U12P heat sink fit the new socket.
    :D
  2. mikeyman198
    mikeyman198 Lets pretend this is hilarious.
    12 May 2011
    If you're going to be overclocking (which I will assume you will be) then there is no real point in getting a 2700K over a 2600K, as the only difference is 100Mhz in the clock speed :) Save the money and spend it elsewhere :) And you will probably have to take the heatsinks off the RAM so the cooler fits :)
  3. HandMadeAndroid
    18 Feb 2005
    Suppose I could get a new cooler, but I do have an h50 knocking about :)
  4. rollo
    rollo Modder
    16 May 2008
    20% in benches isnt nessary 20% in real life. If your worried about the power bill buying more high end gear isnt going to reduce it.
    At load with just the cpu counted your not looking at more than a 20watt saving at stock and it gets less at overclocked settings. if you take a 4.5ghz overclock vs the 4ghz most i7s hit each requires around 1.3v to achieve this.
    Want to save real money replace the GPU with onboard graphics that the new intel provides thats how you knock a great big chunk of wattage outta your computer ( 300 + ) If you dont game the proffesional grade GPUs are alot better on power and performance than any gamer GPU can be.
    And id look at how cheaply you can get a 6core cpu for your current intel platform as most 3d programs support the 6core 12 threads cpus very well, You would gain more benifit in that upgrade than a 2700k would ever provide.
    2700k with 580 requires 480 watts of power average on a calculator thats probably not that accurate but
    the i7950 with 580 requires 496 watts of power average
    thats at stock settings the graphics card is 250 watts of that load.
    if you push both to there respective overclocks your well above 600watts of power for full system load at 3d work, overclocking the gpu would push this even higher.
  5. KidMod-Southpaw
    28 Sep 2010
    Just go for the 2600K, same great improvement.
    And yes, get shorter RAM heatsinks. Mind you, I can't see you needing a cooler like the NH- D14 on Sandy Bridge unless you're doing some very serious overclocking!
  6. dave_beast
    dave_beast Enthusiast
    4 Jan 2011
    Suggest waiting for Ivybridge tbh.
  7. Pete J
    Pete J Employed scum
    28 Sep 2009
    No point in upgrading IMHO.
    LGA1366 is a sturdy beast.
    Teelzebub likes this.
  8. Teelzebub
    27 Nov 2009
    Agreed 1366 is still a very fast platform.
  9. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    1366 kicks ass - that's why I just spent a fortune upgrading from 1366 to 1366 :D
    In terms of power draw, it's a non-issue unless you have several rigs folding 24/7 and want to keep costs as low as possible. The cost of running one PC for several hours a day is negligible - I calculated a while ago that if I average 200W of power draw for twelve hours every day it'll cost me £7 a month. To put that in perspective, 360 hours of computer use costs the same as two beers. :)
    3lusive likes this.
  10. Jipa
    5 Feb 2004
    Personally I wouldn't bother. The i7 950 is still beastly, just OC it as far as you feel comfortable with and wait for something else.
  11. 3lusive
    3lusive Minimodder
    5 Feb 2011
    Not worth it atall. Wait till Ivybridge or try pick up a cheap hexcore 970 perhaps?
    LennyRhys likes this.
  12. Mac_Trekkie
    Mac_Trekkie Source Engine's #1 fan!
    10 Sep 2011
    Honestly it won't be worth it until Ivy Bridge. The 950 is an excellent chip and will serve you plenty until Ivy Bridge comes out.
  13. Guest-44432
    Guest-44432 Guest
    I would take Pete J's advice, as he has owned both platforms, and has gone back to his trusty 920.
    To be honest, even Skt 2011 was not worth the upgrade from my 990X. Which now LennyRhys has.
    I would keep your 950 till Ivybridge-E comes out.:thumb:
  14. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    3lusive makes a great suggestion - the i7 970 is the cheapest way to go 32nm and hexcore on the 1366 platform. You can pick one up for £275 if you look around and it's well worth it IMO, especially if you're maxing out all your threads regularly.
  15. HandMadeAndroid
    18 Feb 2005
    You know the 970 seems a really good idea and I'd get 100 for my 950 I guess, but where are they?!! :D
  16. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Ebay is the best place to look. There was a 970 listed for £300 (or best offer) just after I bought the 990X - had I not gone for the 990X I'd certainly have gone for that. Since then there have been a few which have all sold around the £330 mark, which is still a good price considering the performance they offer.
    If you haven't overclocked your 950 yet however, that should definitely be your first port of call.
  17. Zero_UK
    Zero_UK What's a Dremel?
    12 Aug 2008
  18. feathers
    feathers Minimodder
    11 Apr 2009
    Oh yes, the friend with the very expensive Bosch coffee maker.
    Just looking at the mains meter connected to my PC now...
    136 watts idle for i5 2500k at 5ghz using offset+, 16gb 1866mhz ram, 8 x 120mm fans speed controlled by speedfan in windows, 1 x 1.8 amp water pump, 1 x SSD, 1 x Samsung 1TB hard disk, 2 x 560Ti 880mhz. In SLI BF3 can take 450 watts+ If I overclock the 2 x 560Ti to 980mhz with voltage raise the power consumption rises to 520 watts SLI in BF3.
    For all that SLI power of 768 cores I still can't run Ultra settings on 64 player maps. I think it's the 1gb GDDR that kills it really.
    My CPU overclock has all the C-States ENABLED.
  19. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Enabling c-states turns a system green, seriously - my 990X is currently at 4.5GHz, 12 threads, and my system draws hardly anything, maybe 350W when gaming and about 150W idle, if not less.
  20. HandMadeAndroid
    18 Feb 2005
    toying with a LGA 2011 :\
