Blogs Should I get a PSP Go?
Discussion in 'Article Discussion' started by Cutter McJ1b, 6 Jan 2010.
  1. Cutter McJ1b
    Cutter McJ1b Home-cut jibs at discount Prices
    18 Feb 2009
  2. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    Yeah, I sold my GBA - I bought it full of ideas about wasted time on buses I could play it, and in fact used it about twice. Kept the PSP, though - it does more than play games. God the Go's ugly, though - what's wrong with a normal PSP?
  3. harveypooka
    harveypooka Fond of rumpots and crackpots
    8 Jan 2009
    They cost a fortune!
  4. sear
    sear Guest
    Don't buy the PSP Go. If you must get a PSP, get the regular PSP-3000. There is no reason to get the PSP Go whatsoever - it has a smaller screen, it has a less comfortable design, and no disc drive means any games that you previously had are totally useless. On top of that, the base cost is more expensive, and the regular PSP can do all the same PSN stuff the PSP Go can, including downloading retail games. You also have to buy totally new peripherals for it, since Sony decided to make sure nothing old would be compatible with it (apparently a way of consoling retailers, who didn't want to stock the device due to all the games being digital).
  5. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  6. yuusou
    yuusou Multimodder
    5 Nov 2006
    No.
  7. dolphin-promotions
    dolphin-promotions What's a Dremel?
    12 May 2009
    Bought a DS Lite for myself when they first came out. Played it for about 5 hours. It has kept my girlfriend entertained ever since, so i can't complain really.
  8. Omnituens
    Omnituens What's a Dremel?
    5 Apr 2006
    No. Just get FFVII on a normal PSP. It's not PSPGo exclusive, it can be downloaded and played fine on the PSP 1000/2000/3000 models. And they are cheaper, and more comfortable to use (for me at least).
  9. Spiny
    Spiny What's a Dremel?
    6 Sep 2006
    No.
  10. Aracos
    Aracos What's a Dremel?
    11 Feb 2009
    Everyone says no, you know the answer is no, but I have a feeling you'll get one anyway? Is this more like one of those convince me not to get one posts that's hidden as a "should I get one?".
  11. Skiddywinks
    Skiddywinks Minimodder
    10 Aug 2008
    No. There are plenty of other ways of playing FF7 anyway, and at the end of the day, if you really want a portable, a PSP3000 is a much better way to go about it. For the love of God, do not support the PSP Go!
  12. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
  13. flibblesan
    flibblesan Destroyer
    27 Jul 2005
  14. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
    Y....
    I mean no.
  15. andrew8200m
    andrew8200m Multimodder
    4 May 2009
    No. Hunt for the original PSP and if possible the japanese version. The original is better mate and more robust. The japanese version of th original also has a much better screen ;)
    Andy
  16. eek
    eek CAMRA ***.
    23 Jan 2002
    Yes.
    This post is sponsored by j2o - it's metter to bix things up!
  17. Narishma
    Narishma What's a Dremel?
    21 Feb 2008
    As others have said, get the normal PSP-3000 instead. It does everything the PSP Go does and more and cheaper.
  18. nukeman8
    nukeman8 What's a Dremel?
    24 Jul 2008
    just to be different, buy a PS1 with the screen attachment and a battery pack for it.
    Anything's better than the psp go :p
  19. SteveU
    SteveU Minimodder
    19 Jun 2009
    Just save you money and imagine playing FF7 in your head.
    Remember the golden rule about playing older games, they rarely live up to the memory of playing them the first time round!
  20. wyx087
    wyx087 Multimodder
    15 Aug 2007
    no
    how about iPhone 3GS: one device to replace them all. jailbreak it and put PSX on there for your favourite games.
Tags: Add Tags
