Modding silly thought for a mod
Discussion in 'Modding' started by sobriquet, 10 Jan 2002.
  1. sobriquet
    sobriquet What's a Dremel?
    4 Jan 2002
    I've seen etched windows, i've seen the water-filled windows...but here's a funny thing to think about
    an ant farm in between two pieces of glass for a window
    now, mind you, i would never do this...and i doubt anyone will, but it could work if you didn't move the comp around much
    just a silly thought that slid into my strange little head, it might be cool for a kid's computer though...kindof a 2 in 1 deal
  2. sTevE
    sTevE What's a Dremel?
    12 Dec 2001
    LOL, that would be kinda cool. Once you said this an idea popped into my head. What about getting a clear case and putting a antfarm around the whole god damn thing. Wouldnt be sexy (lol) but would be interesting and funny.
  3. Warbear_nG
    Warbear_nG What's a Dremel?
    27 Dec 2001
    as long as they didn't die - and the dirt would help cool it down some too...
  4. Phil
    Phil What's a Dremel?
    19 Jul 2001
    My case has been called a fish tank and I frequently think about actually making it one properly....
    but I think the noise and heat would make the fish ill...or dead
  5. HellFire
    HellFire What's a Dremel?
    27 Apr 2001
    Heat is a problem.... Buy desert ants. ;) :p
  6. Phil
    19 Jul 2001
    can they swim ?
  7. HellFire
    27 Apr 2001
    He was talking about an ant farm, silly.
  8. Slink
    Slink B7
    7 Oct 2001
    RofL:rofl:
  9. relix
    relix Minimodder
    14 Nov 2001
    lol
    yeah, a farm would be cool
  10. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    Tropical fish :D
  11. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    I wanted to do a fish tank mod or some sort of water filled window with bubbles floating up it .... anyway ...
  12. Slink
    Slink B7
    7 Oct 2001
    LadyClocker over @ CCM actuly sugested something like that
    Fish tank pump, pumping air bubles thru water,
    Great idea methinks
  13. Warbear_nG
    27 Dec 2001
    actually that would rock - but instead - I would dio it in the front of the PC in the bezel - less chance of leakage onto computer bits
    fit the pump inside the case and run power out the back
    I might try that actually... put some nice ligting behind
    only thing would be an air vent
    so moving it might be hard
  14. Guest-16
    Guest-16 Guest
    buy a clear PC case, then buy some more acrylic/lexen and melt it together with a gap in between the 2 layers for water. Then glue in a tube with tiny holes in, seal it off, fill it up and pump air into it. Make the outer layer slightly slanted at the top so the air all forms in 1 place, then just put in a "blowhole" or a piece of surgical tubing so you have a chimney which air can escape, but water cant.
    Easy ;)
  15. Slink
    Slink B7
    7 Oct 2001
    the idea was actualy for "e-star" case's,
    Theese case's have like a chrome looking plastic runing round the front,
    Removing that, place the tupe inplace and fill it with water, atach to a fish tank pump and viola,
    to hold it in place she sugested some silocon,
  16. UnLoadeD
    UnLoadeD What's a Dremel?
    2 Jan 2002
    Heres a link for making a water window:
    http://www.gideontech.com/guides/water/
    If i was gonna make one, i would do a few things different, like sealing it from the inside and out, using aquarium sealant(wont cloud water), include check valves and shutoff valves on the air lines, run the vent line in top outside of the case.... also not sure about the actual frame maybe use plexiglass instead of the aluminum, also i wouldnt run the flexible hose thru the holes, i would put something rigid and acttach hose to both ends, you wouldnt want flex where your seals are and finally, petshops sell a thing called a bubble curtain, its a blue foam-like rod that makes very tiny bubbles, you cut to length and then cap it. Damn, the more i talk about this, the more want to do it, and tho the pics on the guide arent very good, you can tell it would look damn kewl wwith nice lighting behind it, maybe even put some UV dye in the water.
    peace.
    UnLoadeD
    PS: I would use distilled water and some anti-algae drops too 8)
  17. brianpodskalny
    brianpodskalny ladies night!
    3 Nov 2001
  18. MrBadidea
    MrBadidea What's a Dremel?
    10 Nov 2001
    Now what would be cool is a Lava-lamp window... ;)
  19. tk421
    tk421 Idiot.
    15 Jan 2002
    did you guys see pi? dont ants eat computers?
  20. pheonix
    pheonix Toot Toot!
    14 Mar 2001
    we (ccm) have done it before
