Modding silly thought for a mod
Discussion in 'Modding' started by sobriquet, 10 Jan 2002.
  1. Shak
    Shak What's a Dremel?
    24 Dec 2001
  2. Guest-16
    Guest-16 Guest
    WAY WAY too hot - you're talking wax melting temps there!
  3. MrBadidea
    MrBadidea What's a Dremel?
    10 Nov 2001
    I actually put a LOT of thought into this some months back, and came up with an idea approching that of the Water window...
    But then one with normal glass, and then replace the other one with that something along the lines of the rear window of a car, see?
    Then I thought about the heat...
    there would be 2 ways to combat it, but it would defenatley make thing run a bit hotter at least...
    • Add another piece of glass again, with some kind of vaccum inbetween it and the heating piece of glass, much like a double glazed window
    • MoRe FaNS!
      [/list=A]
  4. Sinitus
    Sinitus What's a Dremel?
    17 Jan 2002
    LoL I would like to see that one! :D 200 ants going blind because of the UV-light.
  5. Geek
    Geek What's a Dremel?
    21 Nov 2001
    Yeah, but you'd want to find a car with no rear defogger, so that you wouldn't have lines on your window. Also, you'd need to find it from a fairly old car, so that it would be planar rather than curvy. Plus, I'll bet it'd be hella expensive.
    Gordon
  6. Tim S
    Tim S OG
    8 Nov 2001
    If you fancy a trip to a scrap yard in Stoke on Trent, you will find my old metro there, that had a flat back window :rofl:
    (it was heated too :p)
  7. Felix
    Felix What's a Dremel?
    13 Nov 2001
    you could use that heater you call a CPU to make the wax in the lava lamp hot :cool:
  8. Geek
    21 Nov 2001
    Eh, I dunno that I'd trust wax to dissipate heat better than the old HSF. :--)
    Gordon
  9. tk421
    tk421 Idiot.
    15 Jan 2002
    full size lava's get about 180 deg. F
    and if they break they stink like kerosene burning.and hot wax.
  10. Felix
    13 Nov 2001
    so watercool the lava lamp! :p admit it, a lava lit by a CC would look seksi
  11. tk421
    tk421 Idiot.
    15 Jan 2002
    hot glass + cold H2O = BOOM.
    one of the first practical physics lessons you get working in a resturant
  12. Felix
    13 Nov 2001
    well i meant like run a coil around the outside of it.. keep it at a moderate temperature if it starts to get hot... what? are we still talking about this?:rofl:
