Hardware Silverstone Grandia GD03 Review
Discussion in 'Article Discussion' started by Sifter3000, 21 Jan 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. Jipa
    5 Feb 2004
    With better cooling it would be good for a combined HTPC/file server build. For HTPC alone I can't think of any reason why I wouldn't choose the much smaller, better cooler and cheaper GD-04 instead.
  3. DocWolfe
    DocWolfe What's a Dremel?
    21 Mar 2009
    That's the thing with these silverstone cases... I don't like all the 'vanity panels' that they have... why can't they just make a case where 'vanity panels' aren't needed because what's underneith looks good!?
  4. tonyd223
    tonyd223 king of nothing
    12 Nov 2009
    From the pictures I don't see where the two front mounted 80mm fans can draw air from if the door is closed. So, any chance of you guys doing a media PC build either here or in Custom PC? Please? Would be interesting to see your thoughts on components, and especially on cpu cooler...
  5. ano
    ano 8-bit Bandit
    11 Sep 2009
    Chic is French for stylish or elegance, chique is French for chew.
  6. cybergenics
    cybergenics What's a Dremel?
    27 Jun 2009
    Chic literally means, skill or knack though. Like having a knack at something.
  7. GW42
    GW42 What's a Dremel?
    26 Nov 2009
    And while it's not a major issue for many people, the GD-04 has the advantage that it's the shallowest matx box I could find (I was really tight for space on the depth!) iirc it's only 32-33cm deep, and many others are over 37cm at least.
  8. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    Anyway you look at it. it is fugly...
  9. Jipa
    5 Feb 2004
    I've had both the GD03 and GD04, so I'm well aware of the fact, that's exactly the "choose the much smaller" ;) In fact I think the GD04 might just be the best HTPC-case out there, if you don't need a screen and a remote (out of the box, anyway).
  10. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    why not get a red pulsing LED light system for the front and make it look like Knight Rider....only joking lol but it is very 90's hi-fi separates looking.
  11. ashchap
    ashchap Minimodder
    28 Feb 2005
    I recently set up an HTPC in the GD-04. It seems like a much more suitable case - plenty of airflow and small enough to fit under a TV. Better looking, too.
Tags: Add Tags
